Old 12-11-2014, 08:36 AM
gwynethh's Avatar
gwynethh gwynethh is offline
How to Clean IRIS valve?
We picked up a cheap used manifold for possible use when installing the phenolic spacers (web removal, clean up and clear coating etc.). We removed the IRIS valve and found it very groady. We tried wiping it down with isopropyl alcohol but some of the mung is baked on. Would spray carb or brake cleaner be ok and not damage the diaphragm?
As expected the IRIS oring was pretty crispy.
"Peace is the flower of justice."
Old 12-11-2014, 05:35 PM
Svx95's Avatar
Svx95 Svx95 is offline
eg33svx95
Re: How to Clean IRIS valve?
Sorry, I don't have an answer to your question! Would you happen to have pictures of the process?
Sam
Brilliant Red 95 SVX L AWD 149K miles - #904/1801, 08 STI 6MT with DCCD & VSS, ACT SB10 HDSS, 6MT bushings, DW200 Fuel pump, 17x7.5 VX-SCYTHE Wheels, 17x8 BBS STI Wheels,PERRIN CRANK PULLEY, 911 Turbo oil filter,$15/15min MOD & $20/20min Mod, Brontrager WORKS 22mm RSB w/ QS component endlinks, SS Brake Lines, DDM TUNING 6000K HID LOWS, Hella Optilux Extreme Yellow Fog Lights,Window scratcher fix, JDM Clear Corners
Old 12-11-2014, 05:59 PM
gwynethh's Avatar
What process? We have not done much yet except pulled the IRIS and covered the manifold open ports.
Old 12-12-2014, 10:45 AM
i would use carb cleaner. generally don't want to use brake cleaner on engine parts.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
