Old 12-29-2013, 01:01 PM
theflystyle's Avatar
Engine Trim Cover - Rubber Seat
Im looking for the rubber seal part # that receives the trim cover clip.
I looked at all the part diagrams but havent found this part listed anywhere. In the picture below, its the part that #1 goes into above the throttle body.
1994 SVX LSi
2008 Legacy 3.0R
Old 12-29-2013, 01:38 PM
Re: Engine Trim Cover - Rubber Seat
What you need is the grommet for the collector cover, PN 14096AA001. About $2.45 each.
Here is the diagram showing the right grommet. I did not post the other illustration for the left grommet, as it is the same part number.
Old 12-29-2013, 01:49 PM
Thank you!
Which diagram did that come from?
1994 SVX LSi
2008 Legacy 3.0R
Old 12-29-2013, 01:54 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
24236 AA001 Clip-no.7
http://www.ebay.com/sch/m.html?_odkw...aa001&_sacat=0
This seller has lots of other SVX stuff
Old 12-29-2013, 02:33 PM
Originally Posted by SURTEESS View Post
24236AA001 Clip-no.7
Except he is selling a $3.33 part for $11.50
Old 12-29-2013, 02:52 PM
Originally Posted by theflystyle View Post
Thank you!
https://www.wuala.com/dbarnblatt/Photos/SVX
The Complete parts catalog 1992-94. Was in the engine section. Throttle Chamber System, pg. 90.
Download these while you can.
Old 12-29-2013, 03:53 PM
SURTEESS's Avatar
oops my mistake - thought he wanted the clip - thanks for correcting me.
Old 12-29-2013, 06:28 PM
Thanks again.
Im going to try to see if any local dealers have them in stock.
1994 SVX LSi
2008 Legacy 3.0R
Old 12-29-2013, 09:29 PM
dbarnblatt's Avatar
This link will be active for the forseeable future, as it is on my file sharing site.
If it ever needs to be moved, I will definitely let the network know when and where. I hope these scans I did are helpful to many in the future!
