Old 12-26-2013, 12:22 PM
92 SVX 92 SVX is offline
headlight teardown
Ok I have searched high and low, and cant seem to find any tear down information but seen several postings about it being done.
I am looking for info on how to pull the reflectors and projector out and redoing/maybe even retrofitting a D2S HID bi-xenon.
Old 12-26-2013, 01:07 PM
Re: headlight teardown
Start HERE
Old 12-26-2013, 01:36 PM
Very simple, remove all 6-7 outer clips that hold the headlight chassis from the front outer lens, then cook the headlight in the oven for 5-7 minutes at 200deg, pull the outer lens from the chassis. Then keep turning both rear screws (that control the elevation/direction of the inner lens) until they pop from the chassis. There will still be a ball clip inside that you have to deal with and the rest is easy.
Old 12-26-2013, 02:42 PM
Start HERE
Thanks, I was not talking about pulling the lens off, I been there done that,
http://www.subaru-svx.net/forum/showthread.php?t=56334
What I was trying to find was how to pull the reflector and what Silver just described the adjuster screws.
I did manage to get it but that ball clip gave me lots of trouble it would not pop, I ended up pushing it off with a long screw driver from the projector hole in the back.
