Old 12-07-2013, 10:08 AM
Brian's Avatar
Brian Brian is offline
Seat back: Manual adjustment for power seats?
My power seat's seat back only moves forward, not backwards! In September a friend mistakenly moved it forward, and since then I've been uncomfortably driving around with the angle between the seat back and bottom at 90 degrees, if not less! It had occasionally acted up before, but since this summer, it's been completely inoperative in the backwards direction. Is there a way to manually adjust the seat back, some kind of release or adjustment screw? Or is there any other way to fix it w/o removing the seat?
If it gets moved any farther forward, the car will essentially be undrivable. I'm afraid to try to move it all the way forward to see if it would go backwards after hitting its forward stop. If worse comes to worse, I can always put the manual seat back in, but I'm not sure what condition it's in now.
