Old 12-05-2013, 08:44 PM
Tire Fitment
I know that 225/45R17 tires are a good option in place of the 225/50R16's Speedometer reads almost identical.
I was asked whether a 235/45R17 or 245/45R17 tires would work. Something about wanting to fill up the wheel openings a little more.
Has anyone done it or has suggestions or advice? Here are the calculations
Using OEM 225/50R16 tires, and your speedo reads 65 mph...
225/45R17 tires will read 65.3 mph
235/45R17 tires will read 66.23 mph
245/45R17 tires will read 67.15 mph
Old 12-05-2013, 09:32 PM
Re: Tire Fitment
John,
I have had 245/45/17s on the Claret for quite a while now.
But its a 4.44 so with the gear advantage I'm not worried about hurting the transmission.
On my white XT6, the day I installed taller tires the lock up TQ blew out.
Old 12-06-2013, 05:17 AM
Re: Tire Fitment
One thing I would do is take the car for a spin with a GPS speedo (smartphone app) onboard and see just how far out the car's speedo is. My SVX reads faster than true speed, so a taller tire would actually make my gauge more accurate.
Old 12-06-2013, 06:57 AM
Tireiron Tireiron is offline
Re: Tire Fitment
A larger diameter tire makes the speedometer read slower, not faster, at the same true speed.
Old 12-06-2013, 07:08 AM
Re: Tire Fitment
Sorry, I misspoke. My speedo reads faster that I'm actually going. 100 KPH on the gauge is around 93 on GPS.
Old 12-06-2013, 07:47 AM
dragoontwo dragoontwo is offline
Re: Tire Fitment
Don't forget to also compare them against the '97 tire size of 215/55R16. Then the 235/45R17 is almost identical. I run 235/45R17 and the speedometer is pretty dead on with the GPS.
'92 SVX LS Pearl White - 6mt
Old 12-06-2013, 09:46 AM
Re: Tire Fitment
Old 12-06-2013, 04:11 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Re: Tire Fitment
Maybe I missed it but, how accurate is the SVX speedometer to start with?
Gene
Gene and Ben
Old 12-06-2013, 04:13 PM
Re: Tire Fitment
Gene
uSUALLY IT READS ABOUT 3MPH HIGHER THAN ACTUAL SPEED ON A STOCK svx AT 65 MPH, IN MY EXPERIENCE.
What is a "cap lock?"
Old 12-06-2013, 04:27 PM
bwb3's Avatar
Re: Tire Fitment
If I understand this interweb stuff right, cap lock means you are an Angry Bird.
Gene
Gene and Ben
Old 12-06-2013, 04:45 PM
Re: Tire Fitment
Gene
That sounds logical.
Old 12-07-2013, 10:50 AM
Re: Tire Fitment
Nothing to see here I guess
Old 12-07-2013, 12:09 PM
Re: Tire Fitment
Sorry about that,dragon. I edited my original post and put in the 235/45R17 tire. Just delete your latest post and the confusion will be gone.
0.1mph difference at 120 and 2/100" of a difference in tire diameter is as perfect as you can get between these 2 tires.
Old 12-07-2013, 02:53 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Re: Tire Fitment
235/45/17 is really close or 245/40/17. The width of the 245 makes up for the shortened height.
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 12-12-2013, 09:34 AM
Re: Tire Fitment
with my 225/45R18 summer tires the speedo is dead on. with the stock size winter tires the speedo reads slightly high.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
