Old 09-16-2013, 01:13 AM
The Molinator
Air Pocket in Coolant??
My SVX is overheating and all new parts??? Radiator, pump, thermostat (thot might be sticking)
Wondering what the air pocket is I've heard about.. Could this be it?
Thanks, JIm
Jim
Old 09-20-2013, 12:29 AM
stiguy's Avatar
stiguy stiguy is offline
Re: Air Pocket in Coolant??
I've heared that jacking it up on the drivers side can help get air bubbles out. Not sure how well it works tho
#1 1994 Ls ebony parts car-rip
#2 1994 L laguna blue - sold
#3 1992 Lsi pearl white - sold
#4 1992 Lsi pearl white -Ate two engines - Rip
#5 1994 L Laguna Blue fwd - Now Awd and manual - 03 wrx 5mt - 18's stern warp st4s - totaled hit a tree
#6 1992 Lsi custom orange parts car
#7 1992 Lsi green 4.44 swap. Currently for sale
#8 1992 Lsi custom pearl white. Project car... sold
#9 1992 Teal 4.44 swapped... sold
#10 1995 Laguna Blue. Sti 19 wheels,
#11 1994 Laguna Blue. Came with #10 engine and trans are out but plan to put it back on the road. Willing to sell it at any time! 😂
Old 09-20-2013, 12:30 AM
stiguy's Avatar
Does it boil out? Or does the gauge just say it hot?
Old 09-20-2013, 09:29 AM
you can get an air pocket under the thermostat that will keep it from opening. when i fill subarus i jack up the front end so the radiator is the highest point, install a funnel that fits snugly in the radiator, and let it run until warm while maintaining a level of coolant in the funnel. shut it off and let it cool down and then it will be full and without air pockets. did the new thermostat have a jiggle valve? a good thermostat usually has one and lets the air pocket out from underneath it.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 09-20-2013, 12:43 PM
Something like this makes it a lot easier and much less messy.
http://shop.advanceautoparts.com/web...sle_22970131-p
Old 09-20-2013, 06:30 PM
bishop bishop is offline
have you checked to make sure your fans were coming on? my svx nearly over heated cause the fan relay died, radiator was still properly bled and everything.
Old 09-22-2013, 01:23 PM
The Molinator
Thanks guys..
Really like the SVXCess funnel kit video .. shudda got one .. after doing it! ..
I jacked up front.. few bubbles came out.. a few ounces low of coolant..
Seems to work.
Crazy that would make the difference??
I did have a few bubbles going into coolant reservoir when shutting off hot engine??
I don't know if the slow leak from the thermostat housing (wrong rubber gasket!) CAUSED more air up top??
Thanks, Jim
Jim
