Old 06-09-2013, 11:07 PM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
Windows go up but not down
So my windows have been acting up recently. I noticed the other day that I could not roll down my passenger front window, yet when I try to roll it up I can hear the motor. When trying to roll the window down, no noise happens at all. This happens using both the master window switch and the passenger switch, so it's definitely not the switches.
Just yesterday this also happened to my driver rear window as well.
Are my regulators/motors going out? Do I need to replace the whole assemblies or just rebuild them so they roll down again?
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 06-10-2013, 08:19 AM
scoobydrvr scoobydrvr is offline
Re: Windows go up but not down
You might check and see if there's an issue with the master switch in the drivers door. IIRC the all of the window controls go through that switch; if there's an issue with the window lock button then you might be getting the problems you're describing. For what it's worth, it's strange that they only work in one direction... :scratches head:
1996 SVX LSi : Work in progress, future garage queen
2013 Acura TSX: Mistake
Old 06-10-2013, 10:16 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Check the switch for dirty contacts.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 06-10-2013, 03:47 PM
EdWindows's Avatar
All the switches?
Also, my driver rear window started going down again. I'm so confused as to what's going on...
Old 06-10-2013, 03:58 PM
Originally Posted by EdWindows View Post
All the switches?
check the breaker under the driver seat. Common place for wires and connections to corrode. How do the sunroof and power seat work?
Also, check for bad grounds.
Old 06-10-2013, 04:44 PM
I had a problem last summer with the windows, seat and sunroof. The wires and relay connections had rotted under the seat as described. In your climate I wouldn't expect it but it's possible.
Old 06-10-2013, 05:39 PM
EdWindows's Avatar
I had no idea there was a breaker under the driver's seat.
Power seat and sunroof work fine. Sunroof motor is a little weak trying to flip up the sunroof, but it's been like that since I bought it.
The window thing started happening a couple weeks ago.
Old 06-11-2013, 06:53 AM
Chris_'s Avatar
Chris_ Chris_ is offline
I have exactly same problem!! About once a month the passenger window doesn´t go up. Everything else works well.
svx my94 vtd EUDM
-custom Spax coilovers
Old 06-11-2013, 09:00 AM
All the switches? ...
For dirty contacts, disassemble the switches for the windows that are acting up. If those check out clean, then check out the master switch in the drivers door. Again, if I remember right (and someone please correct me if I'm wrong) the circuits for all of the window motors go through that switch. If everything is good in, for example, the passenger window switch but the drivers switch has an issue, the passenger window will not work properly.
Old 06-11-2013, 11:19 AM
theflystyle's Avatar
I have the same problem here. I am just too lazy to take the door panel apart and clean the master switch.
I also have the occasional weak sunroof issue.
1994 SVX LSi
2008 Legacy 3.0R
Old 06-11-2013, 12:38 PM
When you disassemble the driver's window switch cluster, hold it upside down. (Or hold it over a bucket or something.) There are little springs and things inside that will fall out if you're not careful. I had a problem with the passenger window not going up from the driver's switch (still went up from the passenger switch). Cleaning the contacts in the driver's switch cleared it up.
Old 06-11-2013, 01:49 PM
EdWindows's Avatar
Like I said though, it won't go down from either the master OR passenger switches.
I'll try taking all of them off and cleaning them with some electrical cleaner.
