Old 04-28-2013, 10:17 PM
Andrew P.'s Avatar
Andrew P. Andrew P. is offline
The Ebony ones are faster.
Warning lights stay on after start-up.
I just noticed Saturday that a few of the warning lights stay on longer than they should after start-up.
The "Steering", "battery", "Stop Light", "e-brake" and "ABS" lights stay on
for around 5 to 10 minutes. Then they flicker and go out.
Any ideas?
Thanks
92' Ebony. Magnaflow exhaust, tinted windows, STI wheels, 97' grille, Bontrager Works SB, ECUtune transaxle and TCU.
77' IHC Scout SSII
Old 04-28-2013, 10:41 PM
ShiuludeSVX's Avatar
Re: Warning lights stay on after start-up.
Any ideas?
Thanks
Alternator should be tested
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 04-28-2013, 11:15 PM
Yes don't delay, get it tested. It may only be a normal problem, but if it is the regulator it can do damage.
Harvey
Old 04-28-2013, 11:18 PM
Tapani Tapani is offline
Belt may be slipping.
I got scared when this happened to me due to a small coolant spill on the belt. I could see the PS pump turning slow. Cleared after the belt dried.
Tapani
Old 04-29-2013, 03:24 AM
Andrew P.'s Avatar
I will check the belt when I get home.(I work night shift)
Also, I will have the alt. checked when the shop opens.
I got the alternator from Maniac Electric Motors last year.
77' IHC Scout SSII
Old 04-29-2013, 05:54 AM
Also check the crank pulley. It's made in 2 halves and may be slipping.
Old 04-29-2013, 10:13 AM
Andrew P.'s Avatar
Replaced crank pulley when timing belt was changed a few months ago.
But thanks.
77' IHC Scout SSII
Old 04-29-2013, 11:38 AM
lightspeedrobot's Avatar
lightspeedrobot lightspeedrobot is offline
Time Travelling Robot
This happened to me just the other day. Tested the alt. Turned out to be the culprit was only pushing 12.2 volts...had it rebuilt at my buddys shop for 66.29 . O'reilly quoted me 209 +50 core..... brushes were worn down. I imagine it was the original factory piece. I just installed a new stereo with 2 amps so I figured that pushed the ol unit over the edge. Fixed the problem before the battery got worked over too. High reccommend having it rebuilt as opposed to a new unit... support local plus save money
Ps: you're right, the ebony ones are faster
Teamwork makes the Dream work!
Old 04-30-2013, 04:03 PM
Andrew P.'s Avatar
My car is still at the shop. They are still trying to track down the problem.
At least the alternator and battery both checked good.
I may not get it back until Thursday. Plus I'll still take it in the shorts for the labor of troubleshooting even if they can't find anything.
77' IHC Scout SSII
