Old 04-26-2013, 09:58 AM
Huskymaniac's Avatar
Uses the ignore feature
Re: Transmission Drain
Originally Posted by simboglide View Post
Last but no least,,, Diff lube....did the the factory use synthetc or dino?
I think it was Dino but I like Redline gear oil. Since you only change it every 60K, I can justify the expense.
Tony
Old 04-27-2013, 06:55 PM
simboglide's Avatar
simboglide simboglide is offline
well tranny and diffs are done..dirty on all 3, I'm sure the Seafoam had something to do with the transmissions and the magnets on all three left me with a smile, nothing but very fine metallic dust on them. Now, is there not a magnet on the tranny drain plug?Mine didn't, but when i dropped the pan I noticed a factory "nipple" in directly under the rectangular opening in the filter with a "donut" magnet about the size of a golf ball and and 3/8 of an in. thick.
NE ways.....didn't add the Lubegard yes as I'll be draining and refilling next week and, but my torque bind is gone now in tight turns.
Old 04-27-2013, 09:27 PM
dragoontwo dragoontwo is offline
The drain plug on the transmission doesn't have a magnet. The magnet is in the fluid pan.
'92 SVX LS Pearl White - 6mt
Old 04-28-2013, 07:00 AM
simboglide's Avatar
Yep..I found that out.. did the factory use silicone on the pan and no gasket?
Old 04-28-2013, 07:16 AM
Blacky Blacky is online now
I believe so.
Old 04-28-2013, 07:34 AM
simboglide's Avatar
Means either the transmission has never been into or, someone did it just like the factory using red silicone.
Old 04-28-2013, 07:42 AM
My transmission had a gasket, and the parts listing for the car has a gasket.
Old 04-28-2013, 11:27 AM
It's the oil pan which has no gasket then. The transmission does.
Old 04-28-2013, 01:06 PM
simboglide's Avatar
Looked a little sloppy to be factory and no gasket.
