Re: Time for a bunch of preventative maintenance
It's fun to spend other people's money. :P
If you sell it, I will take you up on your charitable offer for a knock sensor!
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
Rather than disassembling some of the same things multiple times and taking multiple weekends, maybe stockpile all the parts over the next few months and take one good weekend to do it all.
But if that doesn't work out, I will probably have to split this stuff up and group things in a way that makes sense. For example, even I know that you want to do the timing belt and water pump at the same time. After reading this forum for two years I also know that the associated pullies and seals should be done, if necessary, at the same time. Since I am close to also neededing to flush the coolant, I'm guessing that would make sense to do it with the water pump. If I do the coolant lines, those too. Anything else on my list? I don't think any of the other stuff needs to be done at the same time as the plugs, or vice-versa. It seems like that is an isolated job which can be added to other stuff but doesn't need to be. I would assume the same is true for the struts and mounts. I like to do the brake fluid, fuel filter and PCV at the same time to keep them on the same schedule. Since the ATF is coming due for a drain and refill, I might as well lump that in with the others. I'm not sure why I would want to combine the vacuum lines with any of these. My lines are in surprisingly good shape. I could see doing them as PM but not necessarily because I am doing any of the other stuff listed above. I would think this would be a separate job I would do, just because. Are the knock sensors easier with the intake manifold off? If so, maybe those should be done when I do the vac lines. The seats I will do when I get them, which may not be until the spring.
Also the PCV is way easier with the mani off. But if the vac lines are as good as you say, then might be better off leaving that all for later. But there is a very high likelihood that you will need a knock sensor or two and fresh vac lines in the next 50k miles or so.
I feel your pain, no idea when the timing belt was last changed and i need to change my cracked radiator so i may as well do all the work at once since ill have everything out. Was going to install phenolic spacers but im already looking at a big chunk of change for these parts and they wont be here till next week if i order them today.
edit: i wasnt going to give the price but it shocked me. I'm doing all the valve cover stuff, full timing belts, water pump, pcv, radiator, and im getting it all at my parts guys cost, im gonna say about 650$ since were still waiting on a few things. think im gonna be sick.
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. Last edited by bishop; 09-28-2012 at 02:26 PM. |
Thread Tools | |
Display Modes | |
