Old 07-26-2012, 05:20 AM
steveherman steveherman is offline
SSM
i am looking for the cheapest best way to get SSM for my 94.
i am willing to pay more for better software (better means functionality... not ability to change gauge colors and useless stuff)
i am also in need of the cable.
what is a good choice?
what is a better choice?
there is freessm
there is LANs (i think it has ssm)
any other help would be greatly appreciated!!!
Old 07-26-2012, 06:28 AM
Huskymaniac's Avatar
Uses the ignore feature
Re: SSM
there is freessm
Look the scangauge thread.
Tony
Old 07-26-2012, 06:45 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Re: SSM
http://www.alcyone.org.uk/ssm/software.html
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 07-26-2012, 09:13 PM
cruisen_15's Avatar
Re: SSM
I do have an SSM2 but no cables or catridges to go with it. not sure if thats any help
Old 07-26-2012, 09:55 PM
Re: SSM
Cool...
pm sent
Old 07-27-2012, 09:28 PM
Re: SSM
Anyone got any places to get cables?
I saw LANs... 100 bucks for them cables... advice please?
I would rather buy than build my own.
Old 07-27-2012, 09:32 PM
Re: SSM
I saw that thread.
I think.
people were recommending other programs and it went all over the place.
Going to revisit it again.
Old 07-27-2012, 09:41 PM
Re: SSM
Steve, if you buy the parts, I can put it together for you.
Old 07-27-2012, 09:58 PM
Re: SSM
Re read the scangauge thread.
Got to reading about evoscan.
Is the evoscan only ssm2?
Is ssm2 compatible with 1994 obd1?
Old 07-27-2012, 11:20 PM
jellybytes2 jellybytes2 is offline
soup IS good food
Re: SSM
The torque app for Android has SSM support using certain adapters. Googleit and search their forums for SSM. From what I read you can connect to the port on the pre-96 cars.
'97 SVX 'Brilliant' Reddish
'94 SVX Lagina
'93 SVX Less Reddish
'89 XT6
'08 Impreza
'18 Crosstrek
Totaled
'98 LGT ~180K
'97 OBW ~185k
Sold
'89 XT6
'04 VDC Sedan
Parts
'89 XT6
'96 SVX
Old 07-28-2012, 07:52 AM
Re: SSM
I should be getting it at the end of next week to try it out but it sounds like it will do SSM1 or SSM2, depending on the cable you use. The cable I am getting has the SSM1 connector for pre 1996 cars but also has a connector that will access the SSM pins in the OBD2 port on 1996 to 1998 cars. Those cars supposedly speak SSM1.
I also bought the OBD2/SSM2 cable for my Tribeca.
Tony
Old 07-28-2012, 09:26 AM
Re: SSM
Did u order the cable from evoscan? The $57 one?
Did u get their software?
Ur svx is obd2?
Does ssm1=obd1?
And ssm2=obd2?
Old 07-29-2012, 04:12 AM
b3lha's Avatar
Phil & Belha
Re: SSM
When electronic diagnostics first became available, each car manufacturer had their own different protocol for the scantool to talk to the car.
Subaru had a system in the late 80's that we call SSM0 and then in the early 90's they upgraded to SSM1. Early SVXes speak SSM1.
In the mid-90's the US government mandated a standard protocol called OBD2 for all vehicles, regardless of manufacturer. So Subaru added the
standard OBD2 protocol into the SVX ECU in addition to their own Subaru-specific SSM protocol.
Also in the mid-90's Subaru upgraded their own protocol from SSM1 to SSM2. Late model SVXes speak OBD2 as legally required, and also either SSM1 or SSM2 (but we don't know which one!).
All this only applies in USA because the rest of the world didn't adopt OBD2 until after the SVX ceased production. All non-US models are SSM1 as far as I know.
Anyway, Evoscan can do SSM1, SSM2 and OBD2 so it should work on all SVX.
Old 07-29-2012, 07:23 AM
Re: SSM
Ur svx is obd2?
Does ssm1=obd1?
And ssm2=obd2?
I ordered the $57 SSM1/OBD2 cable and it is on a slow boat from New Zealand. My car is OBD2 and it also uses pins reserved for manufacturers to also communicate using what I believe is SSM1.
Tony
Old 08-02-2012, 08:38 AM
Re: SSM
Holy crap! I just found out that I won't get the cable until the 20th! Why the hell does it take so long to ship stuff from Kiwiland!?!?!?!
Tony
