Old 05-04-2012, 10:52 AM
redlightningsvx's Avatar
Collision Refinishing Tech
Re: Cut off and wrecked the svx bad
Pulled the pan and shook the rods to see if they had movement in them. They seem fine and no wierd chunks or particles in the pan or oil.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 05-04-2012, 02:23 PM
Well put the pan back on and started to prep the motor to be taken out. I'm pretty much down to disconnecting the power steering hard line, unbolting the crossmember, unbolt the exhaust and thats about it. Once that's done all I can do is wait until my damn lottery check comes in to fix it which is late by the way
Seth
Past subies:
Other toys:
Old 05-12-2012, 09:19 PM
Well got the motor pulled and the flex plate is NOT broke so it looks like im replacing the motor. Also the C clip in the front diff popped out a little where the tourqe converter goes so I need to get a pick in there to put it back in place.
Seth
Past subies:
Other toys:
Old 05-13-2012, 05:40 AM
Crap...
Did you take the flex plate off? I've seen cracks try to hide behind that small inner ring that couldn't be seen when it was in place.
Old 05-13-2012, 07:35 AM
didnt take it off yet to check
Seth
Past subies:
Other toys:
Old 05-13-2012, 06:05 PM
pulled it off with no cracks, also pulled the sleeve that clips on the TC and the C-clip is bent and one of the hooks is snapped off, probably from pulling the motor ohh well.
Seth
Past subies:
Other toys:
Old 05-13-2012, 10:12 PM
PICS.........................
Clip bent and broke, also seal is dry and broke
Mystery green liquid leak found
Seth
Past subies:
Other toys:
Old 05-14-2012, 03:01 PM
Green1995SVX's Avatar
I'd like to point out that I was right about the leaky motor mount! I win!
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 05-14-2012, 06:16 PM
Mike, you win............Nothing
Seth
Past subies:
Other toys:
Old 05-14-2012, 08:28 PM
That hurt.
2009 Volvo C70 T5
2008 Volvo S80 V8
2001 Audi S8
Old 05-15-2012, 03:57 AM
SSSVX's Avatar
SSSVX SSSVX is offline
One teal and One yellow
It sounds hurt.
Found out what's wrong yet?
Need an engine? I have one extra in my storage, low miles, from 96.
-SSSVX
92 LS-L TEAL since Aug '01
92 LS-L YELLOW since Mar '05
Old 05-15-2012, 09:16 AM
Still dont know what the knock was from. I thought flexplate and was wrong, no metal in the oil, plugs looked good, its just wierd. The only thing I found was the c clip to the tc to the 6in shaft to hold them together was broke but i'm guessing from pulling the motor.
Seth
Past subies:
Other toys:
Old 05-16-2012, 12:30 AM
I'm no expert but i'd say this isn't normal?
Seth
Past subies:
Other toys:
Old 05-16-2012, 12:33 PM
The more stuff I tear off this the more i'm contemplating rebuilding it for when i'm in need of it or should I just recycle the short block?
Seth
Past subies:
Other toys:
Old 05-16-2012, 01:08 PM
Rebuild it. Never know when you need a spare.
