Old 03-24-2012, 07:39 PM
kjoyes kjoyes is offline
factory reverse backup light wire color? for backup camera
hi i am looking for a reverse backup light on the factory wiring harness so i can wire up a back up camera? is there a wiring diagram that would tell me what wire to tap in too?
Old 03-24-2012, 08:56 PM
Re: factory reverse backup light wire color? for backup camera
From the FSM.
The 12V power is the brown wire with the yellow stripe. The black wires are to ground.
Old 03-25-2012, 02:40 PM
my aftermarket radio harness has a reverse gear signal wire.
So in order for the radio, to know that i was in reverse i will have to tap in to the brown/yellow wire run that wire to my aftermarket and attach it to the reverse gear signal wire?
also is there a closer location of that wire from the radio?
Old 03-28-2012, 09:59 AM
the switch on the side of trans is pretty easy to get to but i would just put a switch somewhere, a lot of backup cameras and head units take several seconds to switch on and to the different input which can be annoying when you are doing a multi point park job. if you have the switch you can turn it on whenever you want.
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
