Old 03-18-2012, 09:44 PM
VICSVX's Avatar
VICSVX VICSVX is offline
Never Forget
Fwd to awd conversion help
Have my 94L and a 92Ls and want to do a fwd to awd swap. I know most is just remove and replace but is there anything I should know? Tcu removal? How hard to remove shifter assembly? Anything that fwd is missing to make awd work right?
Planning to the swap and get my car running again soon and don't want many surprises
Thanks guys and gals
VICSVX
94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx
Old 03-18-2012, 09:51 PM
Wikedjuggalo's Avatar
Rebuilding
Re: Fwd to awd conversion help
I had mine swapped from FWD to 5spd AWD. Have question you can ask. You will need a rear subframe. it bolts right up, the only different between AWD and FWD (hardware) is rear diff, rear subframe and drive shaft (axles too). You can get all of that from a donor SVX.
Obviously you need AWD transmission. Axles are the same for the front, need to get new ones (unless they are on the way out, might as well replace them at that point).
As far as the TCU, I am not sure, as I switched to 5spd. Maybe ask SVXfiles or 1986Nate
For the record, FWD was only 94 and 95.
Old 03-19-2012, 12:22 AM
Just remove the FWD TCU and plug in the AWD TCU and you're done as far as that is concerned. Other than that, throw the trans in, driveshaft, rear diff and rear axles as well as the rear subframe and you're set. It's actually extremely straight forward.
Old 03-19-2012, 07:55 AM
redlightningsvx's Avatar
Collision Refinishing Tech
If I remember doesn't the FWD light have to be wired in? Also it won't matter but the rear springs have different rates for FWD to AWD but since you would be switching the entire rear end you will be good.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 04-04-2012, 08:22 PM
VICSVX's Avatar
Never Forget
hey guys thanks for replying. sorry for being so late on responding....work tends to do that
anyways, thanks again....just hope it's as easy as it sounds (bolts stripping or breaking ect) how hard is it to remove the transmission anyways? i heart it is a hassle cause of its shear weight and size?
and as for the FWD being only 94-95, i was aware of it which is why it was a FWD for so long..wanted to keep it more rare lol but money is an issue and FWD trans are not easy to find.
thanks again guys
VICSVX
Old 04-04-2012, 09:19 PM
svxAL's Avatar
svxAL svxAL is offline
more windows then a minivan..
nate has a good running fwd trans out of my car since I went fwd 5 speed !
*1994 5 speed, Barcelona Red W/ Black ebony pearl top FWD*murrano wheels,lowered with motorsports springs drilled and slotted rotors 20% tint,swapped in leather seats,full exhaust cat delete,15 min mod, red F&R energy bushings
Old 04-09-2012, 10:36 AM
VICSVX's Avatar
Never Forget
SvxAl thanks lol but I already have the AWD drivetrain lol hope I can get driving soon
VICSVX
