Old 03-17-2012, 01:12 PM
OmegaSVX OmegaSVX is offline
Re: Starting/Running/moving failure
Local parts store should be a good source for wheel bearings. I think others have also got them from Amazon and ebay.
Are you looking for just a stock geared front diff? And what's wrong with the current one? It may be a better option to do a "4.44 swap" using a trans and rear diff from a 96-98 Legacy GT, Outback or Forester. A 5 speed swap is also an option if you enjoy shifting through gears.
And rear axles hardly ever go bad, so finding them from someone parting one out is a pretty safe option.
Well i guess it depends on whats available and the pricing. When I turn the wheel all the way to either side, I get a nasty popping sound... Thought that was the front CV's so replaced those and its still doing it.
So... yea, thats my only thought is that it has to be worn outputs on the diff.
Old 03-17-2012, 01:16 PM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
Omega, I will have said rear axles at the end of March.
Old 03-17-2012, 04:54 PM
PM sent chuck. Thanks!
Old 03-17-2012, 08:03 PM
I'd take a close look at the tie rod ends and ball joints.
As well as the strut mounts.
Does the popping noise come when you are sitting still and turning the wheel lock to lock, or when you are driving?
