Old 02-02-2012, 11:43 AM
KJC Pearlie KJC Pearlie is offline
Desparate
I need the IRIS unit? Its under the intake manifold and my is leaking oil. My mechanic got the intake off but can't find the part. Any help or leads greatly appreciated. Ken 781-258-3046
Old 02-02-2012, 12:28 PM
sicksubie's Avatar
Re: Desparate
I have the whole IRIS valve assembly if you want it and I am in MA
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 02-02-2012, 06:08 PM
Re: Desparate
I am very interested. How can I get in touch with you
Old 02-02-2012, 07:28 PM
immortal_suby's Avatar
Thread Killah
Re: Desparate
You need a new IRIS because it is leaking oil?
Strange.
Is this a trusted subaru mechanic?
Locker Link
2015 BRZ Limited 6MT
Old 02-02-2012, 09:09 PM
Green1995SVX's Avatar
Re: Desparate
Would it leaking oil indicate a bad iris unit, or a PCV issue?
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 02-02-2012, 09:16 PM
Re: Desparate
No, the crank case ventilation is blocked, so it is blowing oil into the manifold, and it runs to the lowest point, the butterfly shaft.
Old 02-02-2012, 10:15 PM
Re: Desparate
Where should I check for crank case ventilation blockage? The PCV valve was replaced a few years ago and I don't put much mileage on the car. It looks to be ok.
Old 02-03-2012, 10:16 PM
Re: Desparate
Check the passages in the air box attached to the throttle bodies. The cam breathers run into each side of it, but they don't open into it, they run right through a passage that comes out on the right hand corner, into a right angled hose that goes into the main air pipe.
Check that the passages that run through it are clear. You will find a lot of oily goo in there.
Old 02-06-2012, 02:51 PM
Re: Desparate
Sorry, meant to send pm to sicksubie
