Can you drop this engine into an SVX?
http://www.ebay.com/itm/JDM-EJ20T-VE...item256abac217
It looks like it comes with everything including the ECU. I suspect, however, that this ECU is not compatible with our TCUs (or maybe it is compatible with the OBD2 ones...). What would be involved in such a swap? If I am correct, these engines were rated at 300HP. Just curious.....
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
Re: Can you drop this engine into an SVX?
Cool ! You know what they say with enough money and muscle any thing can be done . What is the advantage? Looks like less weight and the turbo boost. Sounds like a plan to me <LOL>
Physically fitting it is the easy part. Forget about trying to get it to talk to our TCU. Swap it to an MT and be done with it. Then all you need to do is figure out the wiring to the gauge cluster and eliminate or fake all the various inputs that some of the newer ECU's look for.
You could swap that into an SVX, but you'd almost definitely need an M/T. Also, I think a 2.5T might be a better fit for the SVX because it should have more low-end torque, which would make it more dailyable.
If it has only 40 more hp, i think it would be easier and better to mod our existing engine. Supercharge it!
92 claret-87 xt turbo-93 z28 6 speed-06 cobalt SS |
I believe that has a drive by wire throttle body. That would be a very difficult hurdle to overcome.
2009 Volvo C70 T5 2008 Volvo S80 V8 2006 Range Rover Sport 2001 Audi S8 |
If you go this route, get one with a complete wiring harness. There appear to be plenty of them on Ebay these days.
I made such a swap into a previous Impreza and it was a piece of cake due to it having the complete harness. Would have been a nightmare without... Quote:
'93 Anniversary Edition SVX 122k - 3.7 FD 5MT Swap, ECUtune 1a1, Bontrager RSB, Mad Restoration underway! '20 Honda Ridgeline Custom Oil Caps, Battery Bars, Phenolic Spacers for sale here: http://www.x35design.com |
Thread Tools | |
Display Modes | |
