And now for air filters
So the other side of keeping your engine clean is the air filter. I did a quick search and found this study:
http://www.dieselbombers.com/chevrol...r-testing.html While the AC Delco did have higher air restriction initially, the air restriction rose very gradually while it was catching an amazing amount of dirt. Also, this flow restriction probable has a negligible impact on performance as other parts in the intake are more restrictive. The AC Delco part number for the SVX is A975C and can be found at Summit Racing: http://www.summitracing.com/parts/AC...%7cModel%7cSVX Combine this with the Bosch Premium Oil Filter and the oil will probably still look like new after 7500 miles!
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 07-23-2011 at 03:23 PM. |
Re: And now for air filters
I've got way more miles on my SVX than 7500.
Cool! Thanks for the information
Thread Tools | |
Display Modes | |
