Old 06-21-2011, 01:51 AM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
99 Legacy Outback Trouble Code
Just bought this 99 Outback Wagon 2.5 DOHC with 195k on it for $1200, no rust super clean. Has a misfire in cylinder #3, pulled Code PO303 Engine makes a ticking sound like a sticky lifter, changed oil and added a bottle of valve medic thinking it could be a stuck valve. Any idea what I should do first and what the most likely issue is. Im hoping its not a worst case scenario like a burnt out valve. Car drives and runs decent, but is not running at its best capability. Seller said head gaskets were done at 130k, and more recently timing belt, pump and idlers. Plugs and wires have 50k miles on them. Should I replace the plugs and wires and or coil pack first. Could it be a bad or clogged injector?
Thanks
Dan
1995 POLO LSI 76K MILES SOLD
Old 06-21-2011, 12:20 PM
SVX92-97's Avatar
Re: 99 Legacy Outback Trouble Code
Old 06-21-2011, 02:15 PM
subeman90's Avatar
Soobologist
first thing I would do is swap a plug wire with another one and see if that makes a difference. Next I would pull that specific plug and look at it too. If you still have a problem then go further but I would do that for now.
15 OBW premium w/eyesight
Old 06-21-2011, 03:15 PM
Great looking car.. Where do you find them?
Or does it just take a nice picture <LOL>
Old 06-21-2011, 07:45 PM
michael's Avatar
michael michael is offline
What Potholes ???
You can try swapping injectors too.
Wanted: Steering Wheel
Old 06-22-2011, 09:13 AM
SVX92-97's Avatar
Thanks for tips, I will try that first
Old 07-13-2011, 07:54 PM
SVX92-97's Avatar
Replaced #3 cylinder injector and made a noticeable difference. Car is running better with more power, but still has a constant ticking noise from the pass. side of engine. Its my daily driver and runs and drives decent.
Old 07-14-2011, 04:15 AM
subeman90's Avatar
Soobologist
might be timeing belt tensioner.
Old 07-14-2011, 02:13 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Did it come with a volume control on the radio.
Ticking could be the injector as was stated. My SVX would have a horrible tap from one of the injectors after sitting for the winter. Got it to go away by running the tank down to about an 1/8th of a tank and putting in a couple injector cleaner bottles. Never came back.
