Old 06-06-2011, 02:21 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Re: V8 Swap in a SVX
Originally Posted by crazyhorse View Post
Set in, and back against the firewall, a small(ish) V8 like a chevy, or ford smallblock, Northstar, or just about any import V8 SHOULD fit. that said, getting it low enough to clear the hood, and keep some sembalance of handling, may be troublesome.
Northstar probably not, its those pesky ohcs that get in the way. Of couse going with a carb makes the old small blocks an easy fit.
Old 06-06-2011, 02:29 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
I wouldnt want a Ford in my Subie
1995 POLO LSI 76K MILES SOLD
Old 06-06-2011, 03:04 PM
We have a local who just finished putting a Jag v12 in an MGB:
http://jalopnik.com/5798539/
Old 06-06-2011, 03:55 PM
93tzlegacy 93tzlegacy is offline
ive seen both an eg33 and an LS1 in an 02 wrx, thart would leat me to believe that the ls1 will fit in the svx bay no trouble, you cant tell me that an ls1 is wider than an eg33....
Old 06-06-2011, 04:10 PM
benebob's Avatar
Wider no but it would also have to sit back quite a bit further and cut into the unibody or sit so high the hood would become optional. Can it be made fit, sure, anything can be made to fit. Will it fit without major modifications, not if you want it to run and not break in two.
Old 06-06-2011, 06:20 PM
wohnson89's Avatar
wohnson89 wohnson89 is offline
At home in the flatland
I don't know much but I think it would be pretty awesome to put an engine and trans out of a dodge magnum 6.1L or 5.7L AWD. they only have autos, but still... a 6.1L Hemi SVX...
That intake manifold might look good out of the hood
1992 Subaru SVX LS-L Pearlie
1989 Mazda RX7
2005 Mini Cooper S
Old 06-06-2011, 07:57 PM
crash_2365 crash_2365 is offline
I've actually given quite a bit of thought to this in the last few months seeing as I have one ready for the job in my back yard...
I'm fairly certain the LS/LQ and even the LT/SBC series engines will fit in the engine bay without much issue, especially seeing how they shoehorned them into the F-bodies . The biggest problem I see would be the crossmember. There's no way a stock LS oil pan will work, maybe one for a blazer swap? The pan and the oil pickup would have to be moved to the front of the engine. Even with that I'm still pretty sure the crossmember would have to be modified.
I did see a video not too long ago of an LS swapped STi that retained the all wheel drive, but I wouldn't go that route. I remember reading on here that the unibody is the same/similar to the z32 platform. If you could swap in a z32 rear subframe, you'd have a diff that would be able to hold most mild v8 swaps (VK56 anyone?). The other route you could go would be to use a good ol' 9" or 12 bolt, or whatever solid axle you wanted. The car would have to be back halved, and then you could install some type of rear suspension setup. Most people would probably say a triangulated 4 link, but I like some of the 3 link setups. It all depends on what you want to do with the car. Personally, I would like to look into the IRS route.
As for trannies, I think there is enough room to squeeze in a T-56, so a T-5 or a 700r4/4l60 should fit. Obviously a custom crossmember would have to be made, but that's been done before.
Now to just get it to stop, turn, and slide
^ HEMI FTW
Old 06-06-2011, 09:30 PM
XT6Wagon XT6Wagon is offline
Eh, plenty easy to hang some other diff out there, main issue is the axles and driveshaft modified to match.
Might also be possible to use a C5 drivetrain and just mount the corvette suspension/transaxle back there for even better wieght balance. Whole different level of fabrication though.
That said 05-07 STi R180 diff, axles, hubs, brakes is the easiest upgrade.
Old 06-07-2011, 04:39 AM
Red94Svx Red94Svx is offline
what about putting one of the newer 3.6 or 3.9 subaru h6's in the svx? would it work ?
Old 06-07-2011, 05:01 AM
looking at doing a 3.6 swap in the near future, a mate an i are building a 3.6 gen 1 legacy at the moment with aftermarket ecu and 5mt swap.
Old 06-07-2011, 05:03 AM
theres a 3.9 h6 ??
Old 06-07-2011, 05:10 AM
Cool Re: V8 Swap in a SVX
my bad lolz, im tired its 4:07 am here :/
but yea i want to know how ur swap goes sounds like it will be a helluh fun car when your done with that
Old 06-07-2011, 05:29 AM
mtotor and box are in the car, just have to finish making the engine loom and taping up the body loom, then mod the saab turbo radiator, plumb it up, get a CVshaft and do a shake down.
Old 06-14-2011, 07:18 PM
decline decline is offline
i saw a kid at cars n coffee a couple weeks back with an LS1 in his miata. stock hood. If can fit in there, it could fit in a svx. its the other aforementioned problems you'd have to sort out. It'd be super sic tho
Old 06-14-2011, 09:20 PM
wohnson89's Avatar
http://www.youtube.com/watch?v=avdUe...el_video_title
http://www.youtube.com/watch?v=gPuhA2taax4
ya it fits...
1989 Mazda RX7
2005 Mini Cooper S
