fastest svx?
which svx has the fastest record time? 0-60 and 1/4 mile.
Re: fastest svx?
That would be the Shadow Machine. Used to belong to Tomsvx, aka Young Tom, and now belongs to Letitsnow(Rob). It's had some improvements since it ran a 12.99 in the 1/4 mile at around 106 mph a few years back already if I remember correctly. That was on about 9psi supercharged, stock internals with the Hydra standalone EMS. Since then unless Rob has changed anything, it has a custom 1off intake, 12 psi with meth injection. I don't believe Rob's gotten it to the strip but is using it for AutoX. I'm sure he can elaborate much more.
That is the fastest confirmed SVX. |
Re: fastest svx?
I'm not certain, but I think it was on the 12psi pulley when it ripped that 12.998.
I put the 9psi pulley on in an effort to help the engine last longer. Otherwise, beyond a pair of catch cans, a little tuning, and reinstallation of the rear window wiper (yeh, I DD it), it's pretty much as-was. As promised, it will be driven... appropriately. I took my ol' man for a ride last year. Seems it wasn't what he expected. I'll bring it out to ESTA sometime this season and see what I can do.
Disclaimer: The above post is on the internet. |
Re: fastest svx?
Awwwwwww I want supercharger
The word itself sounds fast
Jared 1992 dark teal SVX LS |
Re: fastest svx?
wow that is nice, how fast is 0-60? i wish i could do this to my svx, ive been on the forums for about 2 years now and im afraid i have lots to learn before ill be able to do this to my car so this one is supercharged huh.. and turbo ones that run strong?
Re: fastest svx?
Also, SVXfiles, aka Old or Original Tom (OT for short) has a centrifugal supercharger on his claret utilizing ECUtune software as well. Not sure on the boost levels. There are a few others with the ECUtune stage 3 supercharger kits (what the shadow machine originated from) but none that have been pushed, used or proven thus far. Also others have started turbo setups but progress has been slow for various reasons. Rob, Couldn't remember if that was when Tom was really starting to push it or not. I do remember that he didn't have the greatest tune on it when he ran it though. Have you messed with the tuning of the hydra much? And I'd DD the car as well, but I'd probably have way too heavy of a right foot and would be spending all my money on gas. Also, sorry for not getting the bracket yet. I'm going to be stripping down an SVX at "itsjusteric"s after Reading so i can mail that bracket from there probably. Just hard to get everything done when I'm only home about half the time or less it seems. send me a PM with your cell # and I can get ahold of you when I get the bracket off. |
Re: fastest svx?
What would the top speed be on that monster?
Re: fastest svx?
Considering our cars from the factory ran about 155, I would guesstimate it could probably do about 175, or more. Hard to tell in all honesty, and with the hood as it is now, you wouldn't really want to get anywere near the top speed as it would probably get destroyed just from the airflow. Also the gearing plays a huge roll. That car has a JDM 6 spd STI transmission with shorter gears than the USDM transmissions. Not sure of the 6th gear ratio on that one.
Re: fastest svx?
what are main things needed to have been changed on the engine to support a supercharger?
Re: fastest svx?
For more boost, then you will need to get lower compression ratio forged pistons, H beam forged rods, etc, etc. |
Re: fastest svx?
Re: fastest svx?
wow, what ever happened to the engine rebuild with larger pistons that CAM was warking on.. it never ran well right? or is it still being worked on?
Re: fastest svx?
Cam is still working on his, but that is a complete N/A build.
Re: fastest svx?
so which one would be easiest to do? turbo, supercarged or n/a rebuild like CAM's?
Re: fastest svx?
I would say NA. I am learning from the mistakes I made during my break in. I am going to replace iacv, aacv, and get the cylinders rehoned. I also have to helacoil my throttle body mounting bolts to the intake manifold. I believe I may have glazed the cylinders by breaking my engine in on royal purple. All in all not an expensive mistake, but UBER time consuming. While the engine is out I am replacing the fuse box, and all wiring harnesses on the front side of the car. It may be a bit until she's up and running again but I am not giving up.
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted |
