Old 11-20-2011, 07:56 PM
Re: Dragoontwo's 6mt swap
Originally Posted by dragoontwo View Post
Update time. Got the crossmember from OLD Tom the other day. Tom, I got it in the car just for you the other day. Am I doing it right?
If you have to ask if you are doing it right.....
BOY!
That crossmember sure looks nice!
Old 11-20-2011, 08:05 PM
dragoontwo dragoontwo is offline
It is a lot easier to admire the craftsmanship in the car like this instead of under it. It will make shifting a bit harder, though....
'92 SVX LS Pearl White - 6mt
Old 11-20-2011, 08:38 PM
You are gona so love the SVX with a standard tranny . I can't believe how much i enjoy mine. If Subi did it in 1992 like they should have they would still be selling them .
Old 11-29-2011, 07:53 PM
Mounting parts are on the way. Tore the shafts out of the trans to change 5th & 6th out to longer ratios. Will press the gears off tomorrow and take them to my machinist to machine the keyways down to fit the new gears. Wouldn't you know that my auto decided to crap the oil pump out, so my current trans is now shot..... Good thing I have a nice manual to put in....
Old 11-29-2011, 09:01 PM
Well that will get this project going...
Longer 5th and 6th ratios will be great. What trans are they from and where did you source them if you don't mind me asking?
And aren't those 6-speed gears nice and beefy?
Old 11-30-2011, 08:15 AM
I can't say for sure what trans they come from, but they should be Legacy spec B gears. The part numbers are: 32364AA100(5&6 driven), 32341AA380(5 drive), 32337AA060(6 drive).
They fit the 07+ 6 speeds without trouble. To use it in my 06 trans, I need to get the key for the 5&6 driven gear machined down to fit the gear. They changed from a thicker keyway to a narrower one in later years. I can't say if the same holds true for the earlier transmissions, but if you call up Rallispec they should be able to tell you. They also sell the keys pre made for $45 a piece.
I should be getting a parts extravaganza tomorrow.
Old 11-30-2011, 05:18 PM
Got the 5th and 6th drive gears swapped and handed the other shaft and gears to the machinist.
Old 12-10-2011, 09:32 PM
Finally got the trans. back together and in shape to put it in the car. Put the car in the garage tonight and mill start with a few little things tomorrow.
Old 12-17-2011, 04:26 PM
Got the beast out today. Time to remove the other ancillary auto parts and prepare for the install.
Old 06-26-2012, 08:36 PM
Longest Transmission Swap EVER...................
It is finally done.* I didn't document the things I did as I would have liked....
*I still have to wire in the DCCD controller, and figure out what to do about the auto overlay for the DCCD info.
Old 06-26-2012, 09:32 PM
smc smc is offline
WOO! Congrats
Old 06-26-2012, 09:40 PM
Congrats indeed. How's she drive?
Did you already get a DCCD controller?
Old 06-27-2012, 05:41 AM
I do have the controller, I'm just waiting on word from the guy I got it from as to wether or not my TPS voltage is correct for the unit I have.
Old 06-27-2012, 09:12 AM
The DCCD pro one?
Old 06-27-2012, 11:54 AM
The DCCD pro one?
Yes. I may wait till I get back home, too.
