Old 03-09-2011, 05:56 PM
The Molinator
Power Steering System - Which Fluid???
I did some work on my PS system.. Replaced old fluid with POWER STEERING FLUID.. . SOme here say it's OK. Some say change immediately!
ATF? or Power Steering Fluid? .. or BOTH OK ?
Whaddayatink???
Thanks, Jim
Jim
Old 03-09-2011, 06:38 PM
thumper_svx's Avatar
thumper_svx thumper_svx is offline
Either committed, or should be
Send a message via ICQ to thumper_svx Send a message via Yahoo to thumper_svx
Re: Power Steering System - Which Fluid???
ATF... no question. PS fluid will cause problems.
Ich bin ein SVXer wieder
My Rides:
Red 1996 SVX LSi (Saffron)
2007 Yamaha FJR1300 (Kaitlin)
Previously owned; green '95 L AWD (sold), black/pearlie '94 LSi (too many problems), Polo Green '96 SVX LSi (apparently notThe end of an era)
Member #2 in the Yahoo! club, been here since the beta-testing days. In dire need of a cheaper hobby.
Old 03-09-2011, 10:22 PM
Manarius's Avatar
Manarius Manarius is offline
It clearly says on the top of the PS Pump lid to use only DEXRON ATF.
-Jason
-Obi Wan Kenobi
Old 03-10-2011, 06:55 AM
Exactly. Anything else basically has the wrong chemical makeup and therefore can cause all kinds of fun with seals, hoses and so on.
Look at BMW for an example of "wrong fluid"; it's widely felt that one of the biggest problems with the recent High Pressure Fuel Pump debacle (referred to as HPFP in the community) is because HPFP's are primarily designed for use in diesel engines. Diesel fuel lubricates seals, but gasoline dries them out. Although there's been no confirmation, the HPFP problem is widely regarded to be because of this.
My Rides:
Old 03-10-2011, 09:25 PM
Since it only takes about a quart of ATF to fill the system, I would replace what you have in there with Dexron.
The turkey baster method works just fine if you dont want to jack up the car.
(Less work, more fluid changes.)
BTW, I have been REALLY pleased with BG Products ATF!
