Old 03-05-2011, 08:38 AM
SVXgarcia SVXgarcia is offline
Send a message via AIM to SVXgarcia
Tension pulley stops spinning
My tension pulley stops spining on and off? Does this mean I need an entire new pulley or are the bearing just worn?
Old 03-05-2011, 11:15 AM
kwren's Avatar
kwren kwren is offline
Re: Tension pulley stops spinning
Which one
Keith
Old 03-05-2011, 11:34 AM
the one thats attached to the tensioner. Does any one have a part number? or can the bearing be replaced?
Old 03-05-2011, 02:45 PM
Timing belt tentioner?
Power steering belt tentioner?
AC belt tentioner?
What Keith said.^^^
Old 03-07-2011, 06:06 AM
dcarrb dcarrb is offline
The AC tensioner pulley recently seized on one of mine. Chunks of the bearing race fell out of the thing when I took it off. Forty-something bucks + shipping from subaruparts.com for the whole deal (sorry I don't have a part number at hand). This one did have a snap ring retaining the bearing, so I imagine the bearing could be replaced. Don't know about sourcing or how the cost would compare.
dcb
Old 03-07-2011, 01:24 PM
if you can read the number on the bearing you can get one from napa. they stock lots of bearing but don't list them for svx applications. the part numbers on bearings actually give you the size and type of bearing so they should be able to give you the right one.
Old 03-08-2011, 06:01 AM
AC tensioner pulley: Subaru part 73015PA000, "list" price $61.05
PS/ALT tensioner pulley: Subaru part 34413PA001, "list" price $54.98
dcb
Old 03-22-2011, 04:41 PM
thanks for the info. the pulley needed was the PS/ALT tensioner pulley: Subaru part 34413PA001.
I replaced the pulley and now it doesn't seize anymore, however the pulley still makes a noise almost as if it wanted to seize again. The pulley is not firm even if I tighten the nut all very tight. It has some wobble to it and I know it should be firm. the washer that goes before the nut is there where it belongs so i'm not sure what the problem could be as to why it doesn't sit firm.
