5sp ??
FINALly put a 5 speed in my car but now Idk if it drives right? I have a 99 impreza trans with matchig diff 3.90 and not sure how hard 1st and 2nd pull? ANYone know? Seems sluggish to me but could be just the gearing or the trans is bad? Drives fine other then that
VICSVX 94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx |
Re: 5sp ??
1994 SVX L - FWD Barcelona Red 190K miles ~ SOLD 1994 SVX LS - 5spd AWD Emerald Green 202k miles PWR Radiator, HID 5000k, New paint job with issues, 17" STI BBS wheels, converted to 5spd AWD from FWD. Purchased from SVXyGirl 2/20/09 -- Undergoing complete rebuild 1993 Justy 4wd 5door- Teal of sorts , beater. 2008 OBXT Newport Pearl 65k miles |
Re: 5sp ??
In 1st and 2nd, the RPMs go high but the speed barely increases...it shifts fine but not sure how its suppose to drive. Idk if that makes sense lol it doesn't pull like i thought it would I guess....
Re: 5sp ??
Did you put a new clutch in? what did you use? Sounds more like a badly slipping clutch. Might be out of adjustment as well...
Re: 5sp ??
How high rpms are we talking and what speeds. it does sound clutch related
Re: 5sp ??
Exactly what I thought so I put a new clutch in on Sat. It's an ACT and the flywheel looked perfect. SO Idk what the problem is. Pedal feels fine....
Re: 5sp ??
Also put a new throw-out bearing and pressure plate in too....
Re: 5sp ??
It may not have any clearance between the throw out and the pressure plate. Check the throw out fork to see if there is some freeplay.
Re: 5sp ??
Did you get the flywheel cut/turned?
Re: 5sp ??
What do you mean by checking free play between throug-out bearing and flywheel?
ANd no I didn't get the flywheel tuned...
Re: 5sp ??
2010 Subaru WRX 1992 SVX LS-L 89k miles-SOLD! KTM 250sx MX bike aka "Killer Pumpkin" Last edited by Bonestock; 02-04-2011 at 08:22 PM. |
Re: 5sp ??
i havent...
Re: 5sp ??
Not exactly the right place to post this bro.
Re: 5sp ??
Re: 5sp ??
No dude, he has a specific problem related to a 5-speed that's already in his car.
Thread Tools | |
Display Modes | |
