Old 01-26-2011, 07:13 PM
immortal_suby's Avatar
Thread Killah
Re: crank pulley and pin
You can use a pulley from just about any late model subaru. Maybe you can get a stock one locally from someone who "upgraded" to a one piece or underdrive.
Locker Link
2015 BRZ Limited 6MT
Old 01-29-2011, 12:43 PM
jamhamm jamhamm is offline
kartboy pulley arrived today along with the woodruff
it's exactly the same as the stock pulley as far as fitment is concerned
ive already got everthing pulled apart so ill start putting the new stuff on later today
Old 01-29-2011, 12:56 PM
North Ursalia North Ursalia is offline
Hi Mr. Penguin!
I had hoped it would fit, good to see they are identical !
Old 01-29-2011, 03:14 PM
kwren's Avatar
kwren kwren is offline
Does anyone besides me believe that if the bolt was torqued down a bit more the problem with the "key, pulley, etc" would never happen?
I bought a new Subaru legacy in 1990 and when it was time for the "40,000 mile, 40 weeks after I purchased it, service-timing belt, etc I took it to a dealer to do it to "preserve" the warranty. They said if I didn't the warranty would be void. A few thousand miles later, I had the "key-pulley" problem and they simply said it was pretty common.
That was the last time it went to the "experts".
300,000 miles later with the Legacy and about 160,000 SVX miles with removal and reinstalling the "big old pulley" no more problems, although I have removed and reinstalled the thing at least 20 times on various different motors.
However, I always torque it down pretty good... with a big break-over bar and a big mauler!
At least 460,000 miles later logic tells me when I do it like that, it "ain't" going anywhere... and it hasn't so far.
Keith
Old 01-29-2011, 03:26 PM
Thread Killah
Keith
You might be on to something.
Maybe I should adopt your hammer method. Or I could stomp on the ratchet to give it enough "foot pounds"
I've had an aluminum pulley strip out after being in place for many years and I used the factory torque settings with a good torque wrench.
Locker Link
Old 01-29-2011, 03:44 PM
Hi Mr. Penguin!
How about more normal torque and some thread locker ?
Old 01-29-2011, 04:38 PM
+1 on that. Prime cause is, not tight enough. Positive fix is mounting the key and pulley with a "lock tight pulley mount" product. This fills any space between the parts, that allow the movement to start. Should also be used on camshaft pulley keys and mounts.
Old 01-29-2011, 07:55 PM
kwren's Avatar
Could we have pictures of the "Or I could stomp on the ratchet to give it enough foot pounds" alternate addition, please
Keith
Old 01-30-2011, 01:18 PM
all back together - used threadlock on the bolt and torqued to factory spec
all is well - thanks for all your help guys
Old 01-30-2011, 04:46 PM
kwren's Avatar
Why...
Keith
Old 01-30-2011, 04:55 PM
Hi Mr. Penguin!
Because I'd rather torque something to factory spec and lock it there with thread locker than overtorque something, possibly stripping the threads or snapping the head of the bolt off . Torque values are set by the engineers for a reason, and I use them where provided. A properly torqued bolt with threadlocker is not going to back out. IMHO, play between the woodruff key and the pulley is what chips and eventually elongates the keyway, not a loose crank bolt.
Old 01-30-2011, 05:28 PM
Yes defiantly. There is a lot of load on that key, it takes all the torsional forces that the crank send to the harmonic balancer. A small amount of backlash, when fitted, will grow to a knocking sound, and fail.
Using a product to fill this backlash will prevent this. Particular the cam shaft pulley fit, of a round key in a square grove.
Old 08-17-2011, 08:45 AM
SVX_MY_BABY's Avatar
What is the correct torque for the bolt?
Peter
