Old 12-15-2010, 02:20 PM
Momo Momo is offline
Water Leak Help
Hi guys,
I have a 1994 Subary SVX L (2 wheal drive), and I have the floor of the left back seat filled with water, and I can not tell where the water is coming from. I checked the trunk, and it is a little wet, but it can't be the path. I also checked under the hood, and it is definitely not the path.
Please help!
Mohamed
Old 12-15-2010, 02:35 PM
dennyo dennyo is offline
Re: Water Leak Help
Sunroof drain tube plugged?
Old 12-15-2010, 04:38 PM
Re: Water Leak Help
sometimes you can find a weird leak by having someone sit in the car and smoke while someone outside the car points a leaf blower or powerful fan at it, the smoke inside the car will be pushed away from the spot that is leaking
Old 12-15-2010, 04:48 PM
Re: Water Leak Help
I don't have a sunroof. Thank you for the thought though!
Mohamed
Old 12-15-2010, 04:51 PM
Cam Cam is offline
Re: Water Leak Help
What kind of condition is your weatherstripping in? The water in the trunk is commonly caused by the tail lights leaking at the seals.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
