Old 12-14-2010, 07:18 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
weird smell
so i got my car inspected tonight, the people were really nice, and they fixed an exhaust leak for me for free so i would pass. but then when i left i noticed a really weird smell coming from the defroster. it's not gas, it's like a chemical smell. i don't know if it's bad or not, it's just weird, but only the defroster, not the heat or anything else. is this cause they fixed my exhaust leak? or something they do when they smog check a car? i'm not sure, but i don't like the smell. it's kinda gross.
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 12-14-2010, 07:57 PM
Cam Cam is offline
Re: weird smell
Does it smell like burning coolant?
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 12-14-2010, 08:09 PM
B 4 You's Avatar
#lolsvx
Re: weird smell
i don't think so. i had that problem a year ago, it smells more foul than sweet.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 12-14-2010, 08:23 PM
B 4 You's Avatar
#lolsvx
Re: weird smell
and i drove my car earlier with no smell. it was just after they inspected it. i think they cleaned something out or used some chemical in the test and it's just residue. it makes me a little nauseated.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 12-14-2010, 09:32 PM
B 4 You's Avatar
#lolsvx
Re: weird smell
well i drove home from work, and the smell gradually decreased, so i think it was residue from something at the shop. it almost smelled like metal, which would make sense since they welded the exhaust.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 12-14-2010, 10:51 PM
Cam Cam is offline
Re: weird smell
Sounds like its nothing to worry about, unless it comes back. good luck
Cam
'92 Ls-L Dark Teal
Old 12-15-2010, 05:25 AM
Re: weird smell
Depending on how "foul" it is, it could be from gear oil if they have to check the differential levels. (not sure how inspections work as we don't have them here)
Also, if they have to check that, the diff dipstick has a notch on some of them so that it rests correctly. If they didn't get the notch in the nothced open spot on the case, it could be coming from there.
Try checking that as well as checking to see if the smell goes away completely when you hit the "circ" button on the climate control. This recirculates the air in the cabin instead of bringing in air from outside the car.
Old 12-15-2010, 09:28 AM
B 4 You's Avatar
#lolsvx
Re: weird smell
where is that dipstick? and i think it was just residue from the shop. it started to smell less like chemicals and more like a mechanic shop. but i didn't even try the circ button yet, i was too busy watching my temp gauge to make sure my cooling system hadn't erupted again. lol
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 12-15-2010, 03:48 PM
Re: weird smell
It's on the passenger side of the transmission. Below all the wiring harnesses and hoses. The dipstick can be either black or I've also seen yellow for the dipstick.
Old 12-15-2010, 06:19 PM
Green1995SVX's Avatar
Re: weird smell
When you're running the heat, are you running it in ECON or AUTO?
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 12-15-2010, 11:06 PM
B 4 You's Avatar
#lolsvx
Re: weird smell
running auto. should i use econ? it's about 15 degrees at night now. i was under the impression that econ is for like 60 degree weather.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 12-16-2010, 06:10 AM
ZMan's Avatar
ZMan ZMan is offline
Re: weird smell
Auto means the a/c will come on if needed, Econ means the a/c will not come on.
Old 12-16-2010, 11:25 AM
B 4 You's Avatar
#lolsvx
Re: weird smell
right, and most likely it won't be needed in below freezing temperatures. right? by the way the smell is completely gone now.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
