Old 11-24-2010, 11:40 AM
moepower moepower is offline
my 1996 svx will not idle
I have checked the timing and the marks are right on the money. I have checked for vacuum leaks and can not find any. I have also checked and replaced all the spark plugs. Any ideas
Old 11-24-2010, 12:01 PM
XT6Wagon XT6Wagon is offline
Re: my 1996 svx will not idle
start by cleanign your battery terminals and the battery cable. On the cable make sure to get the small ground wire to the chassis. Once you have good connections here you can start looking elsewhere for issues. Don't forget that ALL the sensors on the engine will read wrong if you have poor ground if they work at all.
Old 11-24-2010, 08:56 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
But it revs smoothly? Need more info..
Old 11-27-2010, 08:41 PM
The car will revs up without any problem but it will not idle at low rpms
Old 11-27-2010, 08:50 PM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
You may want to adjust the throttle cable...possibly some slight slack there?
1995 Subaru Svx L / AWD
