Old 12-01-2010, 08:17 AM
alia176 alia176 is offline
Re: Clunking -> Rattling -> Squeaking
Originally Posted by processengr View Post
Hi,
Before replacement, the front mounts looked perfect. I couldn't get them to rattle when car was static. Due to the high mileage, I decided to replace all struts and mounts as a pm-the noise went away totally. Then we bought the silver 92 with the exact same noise. Replaced front mounts, problem went away.The removed mounts showed the bearing had developed play. As far as corrosion-the rear mounts are known to rust through and the top hat collapses. When purchased, both of our 92s had serious corrosion in the rear mounts.
Gordon,
Curious, do you happen to have the old parts that were removed? If so, do you see a bearing part # somewhere? Perhaps it's not worth the trouble of replacing the bearing but I was simply curious.
All four of my mounts probably need to be replaced so I was trying to see if I can save a little coin!
Cheers.
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
