speedometer stopped working..
Hi ,
My speedometer stopped working and the " Engine Check Light" came on..Does this relate to a speed sensor ? If yes, what causes this problem and how expensive is a vehicle speed sensor for 1992 SVX? Thanks, I. |
Re: speedometer stopped working..
Likely, the speed sensor on the passenger side of the transmission, on the diff housing, has failed. I don't know the cost, someone will probably provide a link for that. Not too difficult to change.
Special Thanks to Our Friends and Sponsors: * http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/ http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston "QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works, '92 Subaru SVX LS-L Claret ORIGINAL OWNER '92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~ '92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143 '92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117 |
Does the power light flash at startup? That's what mine did when the speed sensor failed in my car. Luckily I had an extra one attached to the 6-speed I bought that arrived the week before. I'm told the sensor is super expensive from Subaru. Best to pick one up from a parting out thread.
Thank you very much, guys!
If it's the sensor, you're lucky. If it's the gear that drives the sensor, you're in for a surprise. To check the operation of the drive gear you need to pull the sensor. Insert a flathead screwdriver where the sensor was in the notch for the sensor. Put a mark on the handle and drive a few feet. If it rotates, it's functioning, if not you have to pull the diff to replace the $2 part. The sensor is located right by the diff dipstick. Good luck, I had both go bad and it cost around $500 to repair. A malfunction with this sensor will mess up all kinds of things from your fans to your cruise control, wipers and awd system.
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
cost me $4100. TH
Kenneth 1997 Subaru SVX LSi "Svetlana" #185 of 640 - 09/1996 - Polo Green Pearl - 34k miles 1992 Subaru SVX LS-L "Everett" #8738 - 01/1992 - Ebony Pearl - 139k miles - 5MT shifty - Sold 07/31/2011 1992 Subaru SVX LS-L "Sven" #1599 - 05/1991 - Claret - 168k miles - Traded 05/11/2005 2023 Subaru Crosstrek Limited CVT - Crystal White Pearl - 2.8k miles 2021 Subaru Forester 2.5i Limited CVT - Horizon Blue Pearl - 17k miles 2023 Volkswagen Jetta S 6MT - Pure White - 2.6k miles 2020 Hyundai Ioniq Limited EV - Ceramic White - 30k miles |
Thread Tools | |
Display Modes | |
