DIY power mode switch?
I'm having a lot of trouble finding info I could use as a "how to" on a DIY power mode switch. I saw a few little things here and there about trying to trick your TCU into thinking there's a hot fluid condition but it resulted in some weird shifting behavior. Also I've seen a few posts pertaining to ECU swapping with JDM cars so that you have the official power mode switch but I'm on a tight budget.
If there's an easy way to cut, splice and solder my way to a snazzy DIY power mode switch would somebody kindly point me in the correct direction? Currently piloting a 95 Ls, what with the gray pleather seats and leather dash trim without the woodgrain. If that helps. |
Re: DIY power mode switch?
The thread for changing into POWER mode by use of a switch can be found HERE It is a long thread, so take your time and familiarize yourself with the procedure and make note of potential difficulties found along the way. Most who have done it really like it. Quick explanation: You have to ground pin A4 on the TCU under the dash. A wire is inserted into this vacant socket and connected to ground. To use a switch to control it, run the ground wire from Pin A4 to your switch, then from the other side of the switch, connect to ground. The switch interrupts the ground circuit. You need to use one of the push-on/push-off type switches .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 10-28-2010 at 06:56 AM. |
1994 SVX L - FWD Barcelona Red 190K miles ~ SOLD 1994 SVX LS - 5spd AWD Emerald Green 202k miles PWR Radiator, HID 5000k, New paint job with issues, 17" STI BBS wheels, converted to 5spd AWD from FWD. Purchased from SVXyGirl 2/20/09 -- Undergoing complete rebuild 1993 Justy 4wd 5door- Teal of sorts , beater. 2008 OBXT Newport Pearl 65k miles |
Definitely AWD
Thank you for the help! |
Strange, I found this thread twice yestarday and missed the parts I was looking for. Thank you again!
Why not do it to a fwd??
Also, I seem to have read somewhere about a circuit that you could wire a switch to and be able to manually engage the lockup torque converter?? Anyone kniew where that info is?
-Steven 1992 SVX Purple and Black 5 speed swap SOLD *1993 SVX Silver and Black *1994 SVX L Barcelona Red FWD |
Why not?
Shifting at a slightly higher rpm, and having more willing downshifts shouldn't be a problem for a stock FWD. One here has installed a Power mode switch, and a TCU/ECU combo that shifts at 7000 rpm, in his FWD.
Special Thanks to Our Friends and Sponsors: * http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/ http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston "QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works, '92 Subaru SVX LS-L Claret ORIGINAL OWNER '92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~ '92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143 '92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117 |
Not sure about that switch to lock up the torque converter. I think there's a lot of potential problems with that and sounds rather scary to me.
There are times though when I really really wish I could just lock it myself when driving on slow roads that won't allow the car to lock it itself but I'm afraid I may experiment with it and cause some damage. |
Yeah, I would be careful using the lockup. I feel it would be nice on a long highway trip with little hills the whole way.
There never has been a switch to control lockup,
as far as I know.
So I've got a little rocker switch grounded at one end and the other end shoved into A4. It was a pain in the ass but I could do it without removing the dash as long as the wheel was up and seat was back...... Results are freaking awesome. Power mode all the time is amazing.
However, I like the idea of using the "manual" button on the shifter for this function. The convenient thing is that it's just 2 pins over, pin A6 with the brown and black wire. I'd like to just pull that pin and move it over to A4 but I can't get my freakin arms in there to do it. I've never pulled the dash apart on one of these before. Is it easy or a mega-huge pain in the ass? |
Having it on the manual button is very convenient; I would highly recommend it. Especially since that button was never of any use to me before. Now I just gotta find a way to change the lettering on the shifter from "manual" to "powerz".
Jon 1997 SVX LSi Bordeaux Pearl 1995 SVX L AWD Polo Green - 277k miles 1986 Pontiac Fiero 3.4L Twin Dual Cam V6 Last edited by Coan; 10-30-2010 at 10:31 PM. |
I'll have to try when it's light out, I can't see anything up there cause i can barely get my head and arm under there, let alone 2 arms. I may have to pull the lower part of the dash.
Wish me luck! |
Well I blew up the reduction gear shortly after doing this mod. I can't provide hard evidence but I already know the front diffs are not great on FWD SVX. I'd rather not push the luck again.
I tried getting back up there to do it without pulling the dash, my problem is that the TCU harnesses are taped and wire tied together rather tightly and I can't pull it far enough away to get bot my hands at it and I can't get scisors up there to cut the tape without 2 good hands. I'll just have to wait till daylight and pull the dash apart.
