Old 05-13-2010, 11:33 AM
redlinedeath redlinedeath is offline
Send a message via AIM to redlinedeath Send a message via Yahoo to redlinedeath
5spd swap brake related question.
i couldnt find toms write up for the 5spd swap. so my question is, im ordering up some stuff for the swap tomorrow before work, but im not absolutely sure if i need to order a brake booster/master cyl along with my pedal assembly and clutch slave/master. if so, does it have to match the pedal set im ordering?
Old 05-13-2010, 12:33 PM
Re: 5spd swap brake related question.
Depends on how you're doing your pedals...
Old 05-13-2010, 04:10 PM
wrx pedal set. jdm ra trans
Old 05-13-2010, 08:05 PM
You can modify the rod that engages the brake master cylinder to still use the SVX booster...
Old 05-14-2010, 01:53 AM
awesome, thanks so much. is it a lot of work, or just a tweak here, grind here type thing? saves me some money then
Old 05-14-2010, 05:15 AM
I can't remember if the rod needs to be shortened of lengthened but it is just a cut and weld back together at the right length. (or possiably the rod from the car the pedal box came from could be the right length...I haven't done one with a hydro clutch, so maybe someone that has will chime in...
Old 05-14-2010, 07:10 AM
RoughSilver92 RoughSilver92 is offline
I used a different booster (wrx iirc), but I am fairly certain that the rod on the stock booster needs shortened. Cut or grind it down and cut some new threads and you should be good to go.
