Old 12-12-2009, 12:14 AM
Dessertrunner's Avatar
Why one bank is running lean other rich
I think I have a bad injector but would like advise, Left bank is really lean and the O2 sensor keeps giving error even when changed. Right bank is flooding. Every now and then the car is missing down low and as you speed up then all of a sudden it takes off. Just like an injector is sticking on.
Any suggestions will be appricated.
Tony
Old 12-12-2009, 02:23 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Re: Why one bank is running lean other rich
Is it possible that the wires for the O2 sensors are crossed over: Left to Right and Right to Left?
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 12-12-2009, 04:25 AM
legacyau legacyau is offline
Hi Tony i have seen in turbo libertys that there is a inherent design flaw that allows one side of the engine to get less fuel than the other, because the releif valve is one the end of the circuit on the engine one cylinder runs out of fuel and goes lean usually killing the piston, they cure that by making parallel fuel rails with inlets on each side, this is usually for higher hp engines or there could be a problem with your pump?
cam
SVX , XV Impreza, H6 Outback
Old 12-12-2009, 04:34 AM
Try running a tank or 2 of TECHRON injector cleaner, they sell it at Walmart, Advance Auto etc. It has worked wonders for me a few times.
Old 12-12-2009, 05:08 AM
michael's Avatar
michael michael is offline
What Potholes ???
When was the last time you peeked at your precats?
Wanted: Steering Wheel
Old 12-12-2009, 05:37 AM
longassname's Avatar
Just some dude.
Install a fuel pressure gage in between the filter and the engine. Fuel pressure should not drop with the ignition off. I'd suspect lower o-rings before the injectors themselves(unless you are trying to use the known clogged injectors).
Old 12-12-2009, 07:14 AM
No Cats. Michael I think you are right about lower o ring. I will try the pressure guage (its not know blocked injectors). I will check some of the other suggestions as well.
Tony
Old 05-10-2010, 06:42 PM
NeedForSpeed NeedForSpeed is offline
Tony
Tony, did you figure out the problem with the fuel, as described in this thread?
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 05-11-2010, 04:14 PM
Sorry didn't see the question,
Yes it was old age with injectors, I replaced them and all the carzy code problem on O2's went away as well.
Interesting thing it was amazing how much power increase I got from changing the injector. I had a old set that came from Mike and when I installed them only a couple were working. Poured injector cleaner in the tank and slowly over the next 2 days they all cleaned up and fired up. Was pretty funny driving around for 2 day on 3 cyclinder with the other 3 deciding to run at random.
Goes like a stung cat now.
Have a great day.
Tony
