Old 11-28-2009, 02:55 AM
Subix's Avatar
Subix Subix is offline
My Other car is a GENIUS Car!
Timing belt cover rubbing? Thumping noise...
Heard some noise under the hood earlier when it was cold and thought another coil pack was going. (light thumping) I pushed against the timing belt cover and the noise went away.
Doesn't seem like a good sign but how do I tighten it up or can I?
1994 subaru svx le 112k
Old 11-28-2009, 08:28 AM
Re: Timing belt cover rubbing? Thumping noise...
I just had this happen to a car a couple weeks ago... The inner cover mounting bushing had gone to **** and/or cover cracked and allowed the cover to push out. MY fix was to use a 6x1mm bolt with a fender washer in place of the original bolt. This grabbed onto the cover and pulled it back in... This is on the driver's side right? Prob the bolt behind the cam gear so you will have to work through the holes in the gear w/ just the front cover off
Old 11-30-2009, 11:30 AM
Maxo's Avatar
Maxo Maxo is offline
I had this problem too... I used a zip tie going from the top corner bolt to the oil filler tube. It worked really well. I eventually did a reseal and just replaced the inner cover.
Old 11-30-2009, 05:20 PM
Subix's Avatar
I'll try the zip tie job for now, at least until after winter. ugh, the other sounds like work lol, thanks guys!
Old 11-30-2009, 06:42 PM
Is there anything zip ties can't fix?
