Old 11-05-2009, 09:46 AM
subeman90's Avatar
Soobologist
clutch for svx conversion
ok so i got my transmission (05 RS 5 speed hydro) and I got a FW out of an early Legacy at Harry's so what clutch should I buy for my swap? Basically can I buy a WRX clutch or??? and what "stage" do you think is best? Which clutches are crap and which are good? I have been looking on ebay and well there are a few choices on there.
Thanks for any help and advise.
15 OBW premium w/eyesight
Old 11-05-2009, 10:30 AM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Re: clutch for svx conversion
I grabbed a ClutchMasters FX100. 70% more grip than 2.5RS (my transaxle's origin) stock... 165hp*1.7=280... That's more than enough.
Old 11-05-2009, 10:58 AM
AFBeefcake's Avatar
Subaru Swapper
I run a stock WRX clutch and it works fine, but a WRX clutch will not work with a Non turbo transmission.
2005 Legacy GT
My WRX's Cardomain Page
Old 11-05-2009, 11:00 AM
NeedForSpeed NeedForSpeed is offline
Interesting, why is that?
We have an 02 WRX 5MT to swap one day
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 11-05-2009, 11:06 AM
RoughSilver92 RoughSilver92 is offline
I used an Exedy KSB04. Check and see if it fits your application. Mine was a 07 impreza 2.5i transmission, so a couple years newer but the KSB04 might work for you as well. The KSB04 is also used with the EZ30R I believe it is, so more that enough bite (mine only slips when its my fault, i.e. letting off the clutch too slowly while pressing the gas, but as soon as I let off the clutch all the way it's solid). It is an Exedy OEM replacement, which is supposed to hold about 30% more power than the stock clutch, and it's at a very good price point. And I just looked it up and wallah... 1999-2005 impreza RS.
Old 11-05-2009, 11:11 AM
AFBeefcake's Avatar
Subaru Swapper
Originally Posted by NeedForSpeed View Post
Interesting, why is that? We have an 02 WRX 5MT to swap one day
As far as I know turbo transmissions use a pull type clutch and non turbo transmissions uses a push clutch.
Allso I think the flywheel is different.
I used a Exedy OEM replacement KSB03 I think.
2005 Legacy GT
Old 11-05-2009, 11:16 AM
So, if swapping a WRX 5-speed, use the WRX flywheel and clutch and everything is good-to-go?
Old 11-05-2009, 11:39 AM
AFBeefcake's Avatar
Subaru Swapper
Yes, but you allso need the Hydro master and slave clutch parts from a wrx to. and a pedle set out of a hydro clutch car.
My car has
2002 WRX transmission
KSB03 clutch kit
2003 WRX flywheel
Hydro rs pedle set
2002 WRX slave clutch
2002 master clutch with a JDM master clutch tank on it.
SS clutch line
moded svx gas pedle
tomsvx crossmember
Legacy drive shaft (swaped the carier bearing with the stock svx one)
group n trany mount
group n motor mounts
group n pich stop
The group n mounts are much better then the stock stuff and made a big diffence for me.
2005 Legacy GT
Old 11-05-2009, 11:47 AM
Thanks,
I have an STI pedal set, hydro and slave. Only need a clutch and pressure plate, plus mount and shifter. It's for Jon's silver, 4.111 aren't enough fun for a college student , clearly evidenced by many college students here
My car has
KSB03 clutch kit
2003 WRX flywheel
Hydro rs pedle set
SS clutch line
moded svx gas pedle
tomsvx crossmember
group n trany mount
group n pich stop
Old 11-05-2009, 12:07 PM
AFBeefcake's Avatar
Subaru Swapper
Thanks,
The KSB03 is the whole clutch kit. cluth disk, pressure plate, and bearing.
Save yourself time and money and get the group n mount to start with
2005 Legacy GT
Old 11-05-2009, 02:13 PM
MiataMania's Avatar
MiataMania MiataMania is offline
42 Autosports
Send a message via AIM to MiataMania
They really do make just about every Subaru feel worlds better, especially the SVX.
1990 Mazda Miata - Undergoing CSP Race Prep
1995 Subaru SVX 5MT - DD
Old 11-05-2009, 02:44 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
I'm running a spec stage 2 for an impreza nonturbo. This is my first 5mt so learning on it wasn't bad, but learning how to drive smoothly was another story. One year later and I can drive it pretty smoothly. I recommend the group n motor mount and trans mount. That way you won't have to replace it again. I haven't noticed any noticeable noise or vibrations from the new mounts.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 11-05-2009, 05:25 PM
Green1995SVX's Avatar
You'll need a clutch for an impreza non-turbo. I used a Spec Stage 2 on mine. Loved it.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 11-05-2009, 06:15 PM
subeman90's Avatar
Soobologist
does this look good to you?
http://cgi.ebay.com/ebaymotors/SPEC-...Q5fAccessories
Old 11-09-2009, 01:34 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
Originally Posted by subeman90 View Post
That should match your interior vinyl paint! Very good choice
