Wont shift from Park
So a few days ago I got my oil changed, then yesterday I got my wheels rotated and the car aligned. Now, the car started up just fine and it worked at first, then the heater cut off. So I turned the car off and back on to see if this would fix the problem. It didn't, but now the car wouldn't shift from Park?! I eventually got it to go and it was running fine. Later that day the same problem where the car wont shift from park. What could this be?
David '94 Laguna Blue L 110,000 5000k Hid's, K&N drop-in filter, leather seats(thanks to mysvxrocks), 350z rims, and now with big dent in rear passenger quarter panel Purchased 12/2007 and lovin it [SIGPIC][/SIGPIC] |
Re: Wont shift from Park
Will the shift selector just not physically move out of the park position? If so, the shift lock could be malfunctioning.
Mike
2009 Volvo C70 T5 2008 Volvo S80 V8 2006 Range Rover Sport 2001 Audi S8 |
Yeah it physically wont shift
While I don't have a solution, the way I put mine in gear is pressing the button immediately ahead of the shifter on the console. I think it is labeled "manual". I don't have the car with me to confirm the label. A tow truck driver did it the first time when I lost all battery power with an alternator short and main fusable link blown. This allowed him to push me off the freeway where I managed to put a wire in for the fusible link and restart the car.
There should be a click when the brake is pressed and the car is running. That is the neutral safty switch closing to allow you to move the shifter. If you don't hear the sound, that may be it. |
Sounds like the Shift Lock button might need to be pressed, or it is somehow malfunctioning.
the manual button is on the shift lever. The shift lock button is on the base of the shifter. Two hands to both press the normal shifter ratchet release, and the other hand to press the shift lock button on the base... it might work. Having the ignition turned to the "on" position, even if the engine isn't running, might not hurt, either.
"What you plan, and what actually happens ain't exactly ever been similar..." ------------ 1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it. 2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan. 1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun. |
I figured out what is wrong. The switch that should be moving when the brake is pressed in isn't releasing. I took it apart and pushed it in myself and got my car home. Any ideas why this would be malfunctioning?
How come some new things don't function? Keith |
I can't believe I opened up that can of worms.
Do 94's have the shift lock override button? If so, just push that while shifting out of park. The shift lock unit (a little electronic box under the center console) is likely toasted. My car is the same, I've lived with it for over a year. *shrug* Subaruparts.com lists them at $108. I'm sure someone here can sell you one for much less.
Yes, how come Mr Green?
Has someone verified that the OP isnt talking about the brake light switch? If that isnt functioning, theres nothing to tell the shift lock to disengage.
The OP should press his brake pedal and see if his brake lights come on before tearing apart his center console..... |
Call me if you want me to come have a look sometime, 541 990 8697
1992 SVX LS-L #1222 Pearl White 1987 GL Turbo wagon, 5 lug conversion, D/R 5 speed (Rice killer) 1992 Dodge Ram 4x4 diesel (car hauler) 1968 Dodge Polara convertible (Camaro killer) 1990 Toyota Corolla FWD auto (330,000 mile grocery getter) 1986 VW Jetta |
I might have to take you up on that this weekend as I have found more things not working. So the shift lock isn't working, cruise control not working, the heater will turn on but wont blow, and the horn doesn't work. I have checked all the fuses that it could be and they are all fine. All of them went out at the same time so they must be connected I just can't seem to figure out how.
There's probably a ground common to all those that's out, my # is 541 990 8697, give me a holler!
