Old 10-24-2009, 10:34 AM
Bohler's Avatar
Bohler Bohler is offline
Re: Timing belt broke, caused collateral damage
Changing the timing belt after it broke has nothing to do with adhering to the torque spec of the camshaft sprocket bolt because changing the timing belt does not require removing it. When lining up the timing marks I only turned the bolt to the right. Only decided to remove the sprocket after my car seemed like it was out of time with all of the timing marks lined up.
Old 10-24-2009, 02:03 PM
michael's Avatar
michael michael is offline
What Potholes ???
That's why I said A:not pointing fingers and B: t-belt/reseal
Wanted: Steering Wheel
Old 10-24-2009, 05:54 PM
What have you decided to do?
Old 10-24-2009, 07:07 PM
Bohler's Avatar
I ordered a new camshaft pulley, comes in on Tuesday, and am going to go with what you suggested Harvey, because I am only looking for a temporary fix for now until I have the time to pull the engine to change the camshaft.
Jarrad
Old 10-24-2009, 07:14 PM
Jarrad
Yes I am sure it will get you through till then. Just file up the key to fill the shape of the groove in the cam shaft, and Lock Tight it.
Old 10-25-2009, 07:27 AM
michael's Avatar
What Potholes ???
If it's not to late you can fill in the missing areas of the cam with liquid steel. If used properly, that stuff is amazing.
Old 10-25-2009, 11:39 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Jarrad
It is my understanding that you dont have to yank the engine to do a camshaft.... maybe I heard wrong? If I am correct it could save you a lot of work though..... id find out for sure.
Old 10-25-2009, 11:46 AM
kwren's Avatar
kwren kwren is offline
Not necessary to pull the engine... You are correct!
Keith
Old 10-27-2009, 03:29 PM
Bohler's Avatar
What all would I have to remove to replace the camshaft, what else would I need to get and how easy is it to do? I thought for sure I would have to take out the engine to get to it. I ordered the cam sprocket on Monday from the Subaru dealership, but apparently there are only four left in the Eastern half of the country so I won't be getting it until Thursday or Friday if I am lucky because they have to ship it from a different warehouse.
Thanks again,
Jarrad
Old 10-27-2009, 07:53 PM
Just the valve cover and the cam caps. It can be done in the car.
Old 03-16-2010, 07:09 PM
Bohler's Avatar
Just got around to attempting to replace my camshaft, I have it loose. Can any one enlighten me on how you get it out of the engine bay with the engine still in?
Old 03-16-2010, 08:28 PM
Bohler's Avatar
Managed to get the camshaft out and the new one in.
Old 03-16-2010, 09:17 PM
NiftySVX NiftySVX is offline
I am curious as to why this is happening. Do we think the cam bolts are working loose or do we think the pully is able to move with a tight bolt? Is the factory spec too low?
Makes me want to check mine. I did a full reseal at 120 K and had that all apart, but I torqued them using the proper tools so the bolt is exactly as tight as it should be.
If this happens to my car...time for some modded cams methinks.
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 03-17-2010, 12:34 AM
kwren's Avatar
I don't think they are working loose. Maybe a rust thing or if removed not aligned properly with the key set correctly before tightening torquing the bolt. this could break the key when tightened and began the rusting-wear process quickly.
Good luck!
Keith
