Old 10-11-2009, 08:10 PM
kwren's Avatar
kwren kwren is offline
:eek: YT, am I in trouble?
Originally Posted by yt View Post
Gotta get the exhaust out of the way. Otherwise before you unbolt the rear, use a pry bar against the CV cup (not the dust cups) and pop out the snap rings retaining them into the diff. Unbolt and drop down. As you lower it the axles will come out of the diff without removing them
I got the cv shafts out ok but one had a snap ring on it, and the other didn't.
The snap ring was on the short shaft, the other shaft with an extra thing on it, smaller around,longer with groves in the the extra length, didn't have its snap ring.
Was the snap ring supposed to come out on each shaft, neither shaft. or what.
Keith
Old 10-11-2009, 08:16 PM
yt yt is offline
Re: :eek: YT, am I in trouble?
not in any trouble. It is typical that the shorter one holds the ring. just be sure the other car does the same
Old 10-11-2009, 09:23 PM
kwren's Avatar
Whewwwwwwww
Keith
