Old 10-03-2009, 07:49 PM
elemgee elemgee is offline
Front End Vibration
Most of my driving is highway, and I remember a time when I thought my SVX had the smoothest ride around. But over the past many months, I get this front end vibration. When I slow down to around 35 mph, it seems like I'm driving on a cobblestone road, its so bad (it doesnt do this All the time, though). I thought it might be that the highway wasnt smooth, but it happens at various places, and I look at other cars when I have this problem and they dont seem to be bouncing up and down like mine. When I'm going around 70 mph, its not that bad, although I still feel some front end vibration. I've had my tires balanced, and a front end alignment. The tires and wheels are relatively new. The brake disks are relatively new as are the pads. I jacked up the front the car and tried to shake each front wheel side to side and up and down, and they didnt shake. I looked over the front suspension and nothing seems loose. So what could it be? Front axle maybe? I miss the way this use to drive. Any help would be appreciated. Thanks.
Larry
Old 10-04-2009, 05:58 AM
immortal_suby's Avatar
Thread Killah
Re: Front End Vibration
Have you rotated the tires front to back? If not please do and let us know if anything changes. It sounds to me like a uniformity problem with the tires.
Locker Link
2015 BRZ Limited 6MT
Old 10-04-2009, 08:05 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
My shaking problem went away after changing my struts and changing my oil (it was low a quart). I'm not sure which one solved the problem, but check your oil first.
Old 10-04-2009, 05:39 PM
I'm pretty good about changing and checking the oil, and it looks fine. And the struts and springs are new. I installed the motorsport springs along with the Koni inserts. The problem existed before I did this install, and still exists. It really seems suspension related. I keep thinking its wheel balancing, so i bought a bubble balancer (hasnt yet arrived) so I can check. Will let you know if its the balancing.
Old 10-04-2009, 06:04 PM
redlightningsvx's Avatar
Collision Refinishing Tech
You mentioned you had a front wheel alignment, is your car AWD? If it is you need to get a four wheel alignment.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 10-04-2009, 07:14 PM
dannmarr's Avatar
I work for my SVX
Did you change the strut mounts too? Have your rims checked if they are bent.
Old 10-04-2009, 10:38 PM
tiv0's Avatar
tiv0 tiv0 is offline
svxless
I would hint towards strut mounts as well. (if you hadnt changed them)
Trevor
Avondale, AZ
1992 LS-L Liquid Silver 126k "BXR6" Sold 3/23/13
1992 LS-L Claret 178k totaled 10/26/09
1987 BMW 325is
60% of the time it works, every time
Old 10-05-2009, 05:37 PM
hi go get your wheels computer balanced ,bubble balancing is only a single plane balance ,most front end parts dont cause wheel shake ,of course a bad axle would but id go the cheap way and balance
Old 10-26-2009, 08:54 PM
I had the tires balanced by a place that used the Hunter GSP9700 and the problem is still there. They also looked at the suspension and didnt see anything obviously wrong. I'm wondering if it could be the tires (they're relatively new) or the front axle.
Larry
Old 10-26-2009, 09:07 PM
Have you done this yet?
Is the vibration only when braking through about 35 or also when cruising and accelerating through that speed?
Old 10-27-2009, 07:23 AM
Yes, I've rotated the tires front to back. And when I swapped out the OEM struts for the Koni inserts, the front mounts really looked pretty good.
