Old 09-15-2009, 02:55 AM
cruisen_15's Avatar
very long turbo project
well this is going to be a long project but heres some of the things ive been doing right now. the motor is going in a 98 legacy gt. everything is being done by only me.
Old 09-15-2009, 03:00 AM
cruisen_15's Avatar
Re: very long turbo project
Old 09-15-2009, 05:29 AM
STeeL25T STeeL25T is offline
Soon to own a fuctional SVX
Send a message via AIM to STeeL25T
Nice work so far!
Old 09-15-2009, 06:19 AM
Originally Posted by STeeL25T View Post
Nice work so far!
Yeah definitely. So what are the plans for the build? Mean what is the list and what did you accomplish so far?
Old 09-15-2009, 12:03 PM
cruisen_15's Avatar
so far what ive done:
polished intake runners
polished throttle body
cleaned the heads and valve covers
painted intake manifold krinkle red
parts that i have already:
sti oil cooler with water pump
adjustable fpr
aem wideband
unorthodox racing pulley
boost guage
hks ssqv
and other small things.
Old 09-15-2009, 12:10 PM
Nice work Cruisen. That should be a sweet finished project.
Did you think to weight the SVX lump before you stripped everything off? The reason I ask is the 4 cylinder from the Leggy GT will be lighter. It will be handy to know what the extra weight difference is going to be, for when you put in your stiffer front springs.
Old 09-15-2009, 12:21 PM
cruisen_15's Avatar
thanks guys, no unfortunatly i didnt weigh it but ill weigh the car before the swap comes and weigh it after...
as or suspension i have kyb struts and h&r lowering springs on my 92 turbo that im going to put on the 98, those are pretty stiff so i think it will do just fine.
i think the hardest part of this project will be when i have to swap wiring harnesses
thats ok though because im taking auto technician classes and by the time the whole swap comes ill feel much better about finishing with a good product
Old 09-15-2009, 03:08 PM
Does and STi water pump bolt up to the EG33? I've been trying to find that out.
Old 09-15-2009, 11:05 PM
cruisen_15's Avatar
well its a version 3-4 sti water pump and i need that because it has the hook up for the oil cooler. i looked and the eg33 one and my sti one seem identical
Old 09-16-2009, 03:09 AM
cruisen_15's Avatar
is the cometic headgaskets the only headgaskets sold for the eg33? and are they sold in pairs or singles for 90$? will they hold my 20+psi
Old 09-16-2009, 05:33 AM
My info says solds individually for 134 bucks each. If you can find them for 90, please hook me up
As far as 20 psi goes, I don't think theres anyone here whos run half that much boost (for very long anyway). I can only think of one person with a decent turbo set up, most FI people have superchargers which are pretty limited in output and pulley sizes imho, and even then theres not a whole lot of people in both categories that built motors. I'll probably be the first to run high boost on a built motor, assuming I can get my junk back together and keep it running. I'll let you know then.
Now answer my waterpump question haha
Old 09-16-2009, 03:16 PM
redlightningsvx's Avatar
Collision Refinishing Tech
The cometic headgaskets are beefy and about $300 for the pair. I seen a set at OT's place and they are very durable.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 09-16-2009, 04:10 PM
Sorry I missed this haha. I was going to use one if it bolted up and looked like the wheel was bigger or something that looked like an upgrade, but you never know. Every STi in the country has a smaller oil pump than we have so ours could very well be better.
Old 09-16-2009, 10:15 PM
cruisen_15's Avatar
as you can see the svx water pump pulley sticks out further than the sti one, not sure if it will work anymore, wont know for a while.
Old 09-17-2009, 01:34 AM
cruisen_15's Avatar
will a gt35r garret be enough or is my boost going to drop by the time i hit 7200rpm?if that works what other brands have a turbo just like the gt35
