Old 07-19-2010, 05:13 PM
Boxersix's Avatar
Boxersix Boxersix is offline
Porsche Autofanatiker
Re: 11:1 CR Race/Street Engine build
Originally Posted by shotgunslade View Post
Hydra. Tom leaned it out a little bit, in my quest to pass emissions. I'm easily passing at 2500, but failed on idle, probably because I had to leave it at the shop and he probably let it sit for a while and the cats cooled off. It failed with very high HC (634 ppm), but a good CO (about 68ppm) and an O2 reading of 2.8%. That tells me the cats weren't working. If they were, and HC was very high, CO would also be high and O2 would be nothing.
Anyway, once it gets warmed up, it runs great. Getting it there is a problem.
yup i saw it was a hydra ems, was just curious as to what your main reference signal was(MAS sensor, MAP sensor, or Alpha N/ TPS)
How's the vacuum on that motor at idle with the cams? I like to hook up just a good old air core handheld vacuum gauge(one that reacts near instantly to even the most minor fluctuations) to see how big cams motors are running while idling. most electronic aftermarket guages have smoothing built in and don't show any flutter when vacuum gets low due to big cams.
Hydra ems has some great tuning abilities for this setup. I would look into the cranking and cold temp ignition timing. Lack of ignition timing on a high comp motor during cranking will make it a ***** to start.
Old 07-21-2010, 05:33 AM
shotgunslade's Avatar
The main reference signal is an MAP sensor. I will have to ask YT to weigh in on how the timing is adjusted at start-up. Need to replace the starter first, however.
Old 07-21-2010, 04:39 PM
Timing was set by Precision for cranking, I never touched it... You would have to hook up a laptop to the serial port with the Hydra Nemesis program for 2.6 to check what the timing is set at
Old 07-22-2010, 05:52 AM
I noted that Vinny Ten does Hydra tuning. One of my track buddies has an Infiniti coupe with a Vinny Ten-built twin turbo engine. He can really make engines sit up on their hind legs and bark. I may have to give them a call, once I get the starter replaced.
