Old 03-30-2009, 06:40 PM
stuartracing stuartracing is offline
Code 12
I just replaced my t/stat....Cleared codes....Did diag. test....showing a code 12, starter sw. or circuit....Any ideas on this one....I used to have ege, and 02 sensor codes, now just this one.....huuuum...
Old 03-30-2009, 11:05 PM
essveeexxee essveeexxee is offline
Re: Code 12
10 characters.
Old 03-30-2009, 11:31 PM
kwren's Avatar
kwren kwren is offline
Re: Code 12
Do you ever have any problem with your starter not functioning?
You don't have the bosch relay on your starter do you?
Just wondering...
Keith
Old 03-31-2009, 06:57 AM
Re: Code 12
Just wondering...
Keith
Every once in a while when I turn the key, it just does a click, turn the key off turn it back on and she starts up....Verry intermintent.....I`ll check out the relay, thankyou.....
The only ground I took off was tge ground cable to clear codes....
Paul....
Old 03-31-2009, 11:10 AM
kwren's Avatar
Re: Code 12
The "very intermittent click" is more likely than not how you got that starter circuit code 12. No problem unless your click becomes more frequent. It probably will
Keith
Old 03-31-2009, 02:01 PM
Re: Code 12
Keith
Yes, I`m sure it`ll get worse,...I`ll keep a look out for sumpin else goin on....
Thanks......
Old 03-31-2009, 04:39 PM
Tuck's Avatar
Tuck Tuck is offline
Re: Code 12
The Bratmobile "click" got increasingly frequent until it would not start. It was the inhibiter switch on the transmission.
Tuck
Old age and treachery will beat youth and skill.
Old 03-31-2009, 08:26 PM
kwren's Avatar
Re: Code 12
Are you sure?
Keith
Old 03-31-2009, 08:27 PM
kwren's Avatar
Re: Code 12
Thanks......
The inhibitor switch is pretty easy to test.
Have to catch it in the act though
Keith
Old 04-01-2009, 07:24 AM
Re: Code 12
Keith
I`ll check that scenario out also....What does the inhibtor switch inhibit????
Old 04-01-2009, 11:22 PM
kwren's Avatar
Re: Code 12
starting in drive, etc!
Keith
