#226
Re: ECU tune Transmission control unit?
#227
one stock and one for a 3.90.
Nightmare is the name of the car... |
#228
I'll buy them.
#229
Performance FWD TCUs are available now. They are $350 and no core is required.
They have the same changes the performance all wheel drive TCUs have. As I have been doing for quite a while now I am publishing the changes so the information isn't lost should I get hit by a bus. 705503 BASECODE =94 US FWD SVX MADE 12-26-2012 C025=E7:THRESHOLD TO TURN ON ATF TEMP WARNING LIGHT DECREASED TO 212F FROM F4 C026=DF:THRESHOLD TO TURN OFF ATF TEMP WARNING LIGHT DECREASED TO 203F FROM EE C027=DF:THRESHOLD TO TURN OFF OVERHEAT MODE DECREASED TO 203F FROM E6 CO28=E7:THESHOLD TO TURN ON OVERHEAT MODE DECREASED TO 212F FROM E9 __________________________________________________ _________________________________________________ CEA2: NORMAL MODE IN D 1-2 (GEAR 1 UPSHIFT) SHIFT MAP FROM TCUMAPS.XLS 0F 00 80 1E 33 C0 3C 19 F0 53 00 F0 FF 00 FF CEB4: NORMAL MODE IN D 2-3 (GEAR 2 UPSHIFT) SHIFT MAP FROM TCUMAPS.XLS 1E 00 80 3C 19 BC 5A 1B F0 95 00 F0 FF 00 FF CEC3: NORMAL MODE IN D 2-1 (GEAR 2 DOWNSHIFT) SHIFT MAP FROM TCUMAPS.XLS (COPY OF POWER MODE MAP) 0F 00 80 0F 00 C0 2D 19 F0 FF 00 FF CFAD: Power MODE IN D 1-2 (GEAR 1 UPSHIFT) SHIFT MAP FROM TCUMAPS.XLS 14 00 80 2B 16 B0 42 2C F0 53 00 F0 FF 00 FF CFBF: Power MODE IN D 2-3 (GEAR 2 UPSHIFT) SHIFT MAP FROM TCUMAPS.XLS 28 00 80 51 0C AC 7E 18 F0 95 00 F0 FF 00 FF __________________________________________________ __________________________________________________ ___ CA81-CA98: 3RD GEAR SOLENOID A MAP FROM SOLAMAPS.XLS 0F 00 1F40 2f 00 4a38 3f 00 4a38 7f 00 4a38 FF 00 4a38 ff 00 4a38 CA99-CAB0: 4TH GEAR SOLENOID A MAP FROM SOLAMAPS.XLS 0F 00 1F40 2f 00 4a38 3f 00 4a38 7f 00 4a38 FF 00 4a38 ff 00 4a38 |
#230
Needforspeed,
Do you have any JDM TCUs to sell? I'd like to know the cash price if you do and how many. Also, I understand you are tinkering with transmissions, I have some hard to come by upgrade parts I would possibly trade if you wanted. Quote:
