Old 12-14-2008, 08:55 PM
liamrh's Avatar
liamrh liamrh is offline
Re: New member, please answer my Q's...
Dumped the oil today, refilled with mobil 1 10w30 + wix 51287 and decided to leave the diff, trans, and plugs for later because it was -15 F outside.
Old 12-18-2008, 09:48 PM
liamrh's Avatar
Also, and I did search ---wait a second
I did search!
I have noticed that it seems that the internal part of my headlight assembly is covered in a fine residue. It also appears that they are plastic? I looked at the threads available, is it really okay to dump these in the oven? Also, does anyone have a good suggestion for mildly cleaning the interior without disassembly? It isn't that bad, but it is occluding my light also. 9006-9005 mod performed. Thanks!
Old 12-19-2008, 06:12 AM
Freeman's Avatar
Freeman Freeman is offline
Unregistered User
Either get clear lenses or if you don't wanna spend that much, get one of those hookup's for your drill and clean the inside with that. There's a how to somewhere about it..
I sugest clear lenses and clear corners..
Old 12-21-2008, 08:37 PM
liamrh's Avatar
Yeah, I used a buffing wheel and some rubbing compound, much better.
Another question, I have noticed that I have no cel on the dash? Anyone else encountered this before? Are the lights easy to replace on the cluster? I found the how-to for removing it. Thanks!
Old 12-21-2008, 09:12 PM
liamrh's Avatar
My other question is where is a good spot to tap into for placing an electric oil psi sender? Do we have galley plugs lurking around? Not for the bling at all, just cause I like to know before the big $$$ sign lights up on the dash.
Old 12-22-2008, 10:00 PM
liamrh's Avatar
Bump!
I know where the stock sender is but I doubt it would be a provident idea to "t" off it to get a reading.
Old 01-11-2009, 09:08 PM
liamrh's Avatar
Quick update:
1. Changed the ATF - I asked around as I was worried about putting 4-6 quarts of subaru ATF - dex IV synth in there and having my 120k 4eat **** all over itself. The consensus seemed to be that it was okay.....no spewing as of yet, let's all cross our fingers.
2. Changed the gear oil out also.
3. Put two new belts on.
4. Visual inspection of Timing belt.....thing looks damn near perfect!! Just enough deflecton, no dings, knicks, or otherwise.
5. Confirmed o-ring on bottom of reservoir is going, glad I ordered it on friday.
6. Did my first plug change, much smoother.
7. Confirmed location of knock sensors as CEl light was out when I bought the car, needs both knocks and a left - 02, all incoming. codes 22 - 28 - 37
8. Measured resistance of resistor, failing.........where can I get a repalcement people? Post up some links please.
Old 01-18-2009, 07:13 PM
liamrh's Avatar
Update two....
1. Yes, taking off the engine lift bracket with the ac attached is a much better way to change the rear knock sensor. Do clip the wings on the harness and make sure you have one of the four pronged flexible retrievers. Helps loads.
2. Replaced left bank 02, had been throwing an intermittent code, sorta sucks to get at the harness though. oxygensensors.com was the best $$$.
Reset all the codes, seems to smooth right along and I can definitely tell the timing is better. Both the old ones were complete open circuits. No cracks or structural failure though.
Next is the crank pulley and the second replacement of the atf along with a new resonator.
