Old 12-05-2008, 06:04 PM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Security question
Programmed my 94 pearl factory security system with a two button keyless ride remote. First of all only one button works to arm and disarm, the lock button, and secondly, it only locks the passenger door. I believe my drivers door lock is fine, because when I push it down by hand it locks both doors, and if I lock from the outside using the key, it also locks both doors. Any idea what it could be. I will try another remote first, and then the security module. Speaking of which, these are obsolete from subaru correct? Does one know what goes bad with these modules, and are they fixable.
1995 POLO LSI 76K MILES SOLD
Old 12-06-2008, 08:01 PM
SVXdc's Avatar
SVXdc SVXdc is offline
Radio wiring harness guru
Re: Security question
The OEM security module only recognizes a single button on the remote. The OEM remote only has one button. Push to change from unlocked/unarmed to locked/armed, and vice-versa.
The problem is not with your security module or remote.
When you lock via the key or the slider lever inside the door, you're locking that door mechanically. Inside the driver's door, a switch causes the passenger door actuator to lock the other door.
Sounds like the door lock actuator in your driver's door (or the wiring or a connector) is bad. Search for older posts — I think some people have fixed the problem by removing the interior door panel and cleaning the contacts. However, in some cases the actuator was fried and had to be replaced.
David C.
Old 12-06-2008, 10:24 PM
SVX92-97's Avatar
Thanks, Ive figured that out. Will see if its the wiring or the actuator itself.
Old 12-18-2008, 06:42 PM
blackbolt94red's Avatar
blackbolt94red blackbolt94red is offline
1st one red, 2nd one black
Post Re: Security question
This might/probably isn't related but it's good to keep in mind. I went for years not using the key to unlock my door, always used the remote. One day I locked it with what turned out to be the last mili-amp of juice in the car battery. Wouldn't unlock the doors, totally dead battery. Because I never used the key, the mechanism was all froze up and I couldn't turn the damn key. Took me hours to work it loose with WD-40. Ton of fun.
Merry Christmas to all, a safe holiday at home with loved ones and friends.
Bruce
“I distrust those people who know so well what God wants them to do, because I notice it always coincides with their own desires.”
Susan B. Anthony
"The Dildo of Karma rarely comes lubed." -- Unknown
The inventor of the doorbell did not own a dog.
