Old 11-25-2008, 04:46 AM
McTaff's Avatar
McTaff McTaff is offline
Mr Soob
Buying a 6 spd
Enough talk.
I'm getting a 6 spd DCCD through 'E'. I'm back in the country mid-Jan and will hopefully get started sometime in the first half of next year. It'll be going in the pearlie. It's my wedding present to me.
'07 Outback (Legacy) Pearl White > 3.0R Premium, stock (50,000km, Wifes daily driver. Owned from new) Not For Sale
'92 SVX Black on Pearl White > 6spd, DCCD on the way. (260,000km, My daily driver, 2 previous owners) Not For Sale
'93 SVX Black on Charcoal > Aftermarket rims.(250,000 km, Dad's daily driver, unknown owners) Not For Sale
'93 SVX Black on Burgundy > Completely stock, under preservation, treated like a princess. (55,000km, 1 previous owner) Not For Sale
'92 SVX Black on Burgundy > Completely stock, under preservation, treated like a princess. (144,000km, 2 previous owners) Not For Sale
Wife, Red Hot when riled > Treated like a princess. Minister For Finance, Domestic Affairs and Diplomatic Relations. Definitely Not For Sale
My Wanted List: http://www.subaru-svx.net/forum/show...178#post632178
Old 11-25-2008, 08:29 PM
dynomatt dynomatt is offline
Re: Buying a 6 spd
Well done...you'll love it
M
Old 11-26-2008, 02:00 PM
Re: Buying a 6 spd
Originally Posted by McTaff View Post
Enough talk.
Good stuff McTaff.
How will you control the DCCD? If you use the TCU from the Impreza, will it work independently of the ECU from the SVX?
Old 11-26-2008, 04:36 PM
McTaff's Avatar
Mr Soob
Re: Buying a 6 spd
The DCCD controller will come with it, as will the R180 w/sensor and so on. What I'm getting is almost a complete kit.
As far as I am aware, the ECU in the SVX doesn't need to receive anything back from the TCU?
I'm certainly not an expert in this area, but there is plenty of knowledge around here to draw on: to be honest the wiring is the part that makes me nervous. In any case, I'm not the first to do this and I'm sure I'll be able to find out here exactly what needs to be done there. I'm not doing the install myself - there are a couple of people on the board who have already offered to help me out and I intend to take full advantage of the experience we have here.
Old 11-26-2008, 05:48 PM
Re: Buying a 6 spd
It is likely the ECU will work OK with the 6 speed, loads of people have put them in.
I'm not too certain of how many may have put in one that uses the DCCD, that's another level of complication. Assuming the DCCD controller "talks" to the gearbox and they get on about their business, I expect all should work OK.
In the SVX the TCU communicates with the ECU. As the gearchanges happen the ECU cuts power [possibly momentarily drops out one side of the flat six, I'm not 100% sure how it works] so that the clutches are saved and the gearchange is smooth. With a manual SVX the ECU does not get this signal, so this communication pattern is not a problem.
However, a problem you will have to overcome is the detente on starting. The engine will not start unless it gets a signal the gearbox is in Neutral or Park. You will have to fool the ECU into "thinking" the auto box is in Neutral.
SFAIK there are possibly two ways to achieve this. The guy putting in your box will probably know how to wire this.
Old 11-26-2008, 06:09 PM
Re: Buying a 6 spd
There is a difference in using the Park or Neutral, for starting the engine. Hopefully Phil will find this, but the engine does a different start up routine when started in P than when started in N. Just my guess.
The other point on the DCCD, is that the original Australian TCU can be set to do the normal control over the center diff in the 6 speed the same as it does in the 4eat with VTD.
Old 11-27-2008, 04:25 AM
legacyau legacyau is offline
Re: Buying a 6 spd
Hey Harvey does the ecu set a different fuel map in neutral as opposed to being in gear ?
cam
Old 11-27-2008, 03:32 PM
Re: Buying a 6 spd
cam
I am not sure where I found this, but it would appear that it does the start up differently. It probably treats the P start more as the first start of the day (depending on the temp) where as the N start, as a restart. I think the fast idle time is altered.
Old 11-27-2008, 03:36 PM
Re: Buying a 6 spd
When I rewired mine, I thought there was only one thick wire that went into the transmission loom. That was effectively the main start feed that went to the starter solenoid. If you short that out, then the starter works everytime you turn the key.
If there was a link to the ECU, I'm not sure how it would work.
Unless there was two wires to the starter solenoid...one for N and one for P and I just don't remember.
Old 11-27-2008, 04:14 PM
Re: Buying a 6 spd
The ECU gets both the P and N signals from the Shift lever switch. It would use this to tell if the car is in gear, or just running at Idle.
It may not make much difference, but I do wonder why it needs to know, if it is in P or N? I think it is to do with the Idle routine.
Old 11-27-2008, 04:17 PM
'E''s Avatar
'E' 'E' is offline
Re: Buying a 6 spd
and here it is..........
92 pearl SVX about to revive
92 Black 4ws (Jap spec) SVX
93 black SVX
93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear
95 bright red SVX
96 emerald pearl SVX about to revive
Old 11-27-2008, 04:30 PM
Re: Buying a 6 spd
That looks like it is a pretty complete kit.
Just got to make it happen.
McTaff's Avatar
Mr Soob
Re: Buying a 6 spd
The Meccano set from hell....
Old 11-27-2008, 11:31 PM
Dessertrunner's Avatar
Re: Buying a 6 spd
Its different on our car from the USA ones as the speedo is throught the TCU so you have to cut a couple of wires. The N & P switch is just to stop the car being started in gear, doesn't have much to do with the rest. Any effect on the idle is not that big an issue. It would take about 3 hours to fix the speedo, cruise and starter circut. Part of this involves poping a diode from the left side of the dash to get the cruise going.
Tony
Old 11-27-2008, 11:49 PM
Re: Buying a 6 spd
Just for the record, the ECU sees a signal at the N & P pins only when there is voltage at them. So if there is no +v to the pins the ECU assumes a P or N state. The fueling *may* be different at start-up but the loaded maps are still the same
