Old 11-24-2008, 11:32 AM
newkid17's Avatar
newkid17 newkid17 is offline
Send a message via AIM to newkid17 Send a message via Yahoo to newkid17
front diff. replacement????
ok so i found out (thanks to you guys) that my pinion bearing in my front diff. is bad... so i was wondering if it is easier to replace the whole front diff. or to replace the pinion bearing only? and if i was to replace the whole front diff. how do i do it. does the tranny have to come out?is there a certin front diff. that i would need or will anything out of a subaru fit? i know that the diff. comes befor the tranny so i am thinking that there is enough room to squeez the front diff out without taking the tranny out. i really do not want to take apart the front diff. just to replace the bearing unless that is alot easier..? i could really use some of your guyses expertees.
Old 11-24-2008, 11:34 AM
Re: front diff. replacement????
The trans will have to come out.
Old 11-24-2008, 11:42 AM
And make sure to change both the ring gear and pinion gear. They are a matched set and both need to be replaced or else premature failure is likely to happen.
Old 11-24-2008, 11:55 AM
newkid17's Avatar
ok so what if i was to just replace the whole front diff.? or is that pointless?
Old 11-24-2008, 11:57 AM
newkid17's Avatar
do i need a sertin type of front diff?
Old 11-24-2008, 12:15 PM
I believe the differential has to be one out of an svx unless you want to replace the rear diff as well.
Someone correct me if I'm wrong as I can't remember for sure if the gearing is in the transmission or the front diff. If the gearing is set by the trans and not the front diff than there are a lot of options for replacing the front diff.
Old 11-24-2008, 12:16 PM
And yes you can just replace the whole differential
Old 11-25-2008, 11:56 AM
newkid17's Avatar
does anyone know if i need a diff. out of an svx or not?
Old 11-25-2008, 12:36 PM
If you use an SVX front diff, you can leave the rear diff alone. If you use a diff out of any other car, You will need to get the rear diff from the same car and convert the LSD carrier from the SVX rear into the new one. There is a writeup on how to do the LSD conversion in svxfiles' signature.
Old 11-25-2008, 02:08 PM
newkid17's Avatar
what about an lsd rear diff? would that work?
Old 11-25-2008, 08:32 PM
newkid17's Avatar
so say i get a front diff with a 4.11..... and a rear diff. with a 4.11 LSD there would be no need to convert the LSD from my origional rear diff to the new diff. right?
Old 11-25-2008, 08:45 PM
Edit: My bad.
Old 11-25-2008, 09:06 PM
No thats still no good. The SVX has a pretty unique rear differential with a viscous LSD. It is the only model subaru that ever got them in the states... Needless to say, no USDM rear diff is going to match the axles... hence why you will need to modify the rear diff
Old 11-25-2008, 09:24 PM
newkid17's Avatar
well i got a 4.44 LSD rear diff for my girlfriends SVX and igot new axles for it too???? will that be good or wont the axle match up with the car?
Old 11-25-2008, 09:32 PM
Axles have different CV sup sizes and they will not fit into the hubs... Like I said, you NEED to convert the rear to the SVX LSD. There is no way around it
