Old 11-19-2008, 02:04 PM
newkid17's Avatar
newkid17 newkid17 is offline
Send a message via AIM to newkid17 Send a message via Yahoo to newkid17
help with a noise
ok i have this noise in the tranny, i put it up on the lift today and had my tech teacher look at it.. its like something broke loose in it and is hitting the transmission caseing. it shifts fine and dont slip or anything. i dont know what it could be?..... any sugestions?
Old 11-20-2008, 12:10 AM
Hondasucks's Avatar
Subaru Technician
Re: help with a noise
Does it do it randomly, or does it do it under specific conditions? I would drain the transmission (17mm plug on the pan, get a new sealing washer from the dealer) and drop the pan and make sure there isn't anything in there, if it's shifting fine, it might just be a loose bracket or something, but sure would suck for it to bounce up into the guts of the tranny and toast something.
I don't know if you can get a tube of Three Bond or not, check with your local Subaru dealer, since as far as I remember there isn't a gasket on the transmission pan, just goo. (Don't use silicone! If anything use a tube of "the right stuff" gasket maker if you can't get a tube of Tree Bond.)
I'll get a PDF from the service manual and attach it, for removal of the pan. I just tried to get it but the site is being a pain in the arse...
1986 VW Jetta
Old 11-22-2008, 08:39 PM
newkid17's Avatar
ok ill do that before i pull the tranny out of it... thank you.. and it does it constiantly, it gets louder as i put on the gas.
Old 11-22-2008, 08:58 PM
Wikedjuggalo's Avatar
Rebuilding
Does it sound like a card in a Bicycle spoke ?
Old 11-22-2008, 08:59 PM
Rebuilding
There is a gasket and the gasket comes in a transmission filter kit
Old 11-23-2008, 12:45 PM
newkid17's Avatar
yea it does sound like a card in a bycycle spoke.....? i dropped the pan today and there was nothing in there....any other cuggestions before i tear the tranny out?
thanks bobby
Old 11-23-2008, 03:43 PM
Rebuilding
thanks bobby
I got bad news for you.... The pinion bearing in your front diff is one its way out and once it goes you'll know. My recently did the same thing. In a matter of 2 days it when from a very soft sound to loud. ONce it got loud it was a matter of 15 miles before it when and took front diff with it.
I could be wrong but ... The guru's on here will probably say the same.
Old 11-23-2008, 05:15 PM
newkid17's Avatar
how do i change that? does the tranny or anything have to come out?
Old 11-23-2008, 05:17 PM
Rebuilding
its part of your front diff meaning your front differential is going bad.
Old 11-23-2008, 05:27 PM
newkid17's Avatar
i cant just change the pinion bearing?
Old 11-23-2008, 05:59 PM
Rebuilding
Not to my knowledge ?
