Old 11-17-2008, 08:28 AM
greggbzz's Avatar
greggbzz greggbzz is offline
Awitha Cheese-ahhh!
Send a message via AIM to greggbzz
Occasional Clunk
I have the occasional "Clunk" when taking off in 1st. It seems to happen either A.) when I am going uphill, or B.) if I start harder then usual.
Basically, right after I let the clutch out and start to accelerate.
It's pretty hard, and only does it once. Not like a CV joint.
I investigated all the linkage and gave the wheels a good shake while it was on jack-stands, it seems real solid. The struts are not leaking.
Old 11-17-2008, 03:12 PM
Re: Occasional Clunk
Rear diff bushings?
Or trans mount??
Old 11-17-2008, 07:24 PM
legacyau legacyau is offline
check the front control arm mounts they can make noise if theyre not tight
Old 11-18-2008, 07:01 AM
zavikan zavikan is offline
+1 to tranny mount
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN!
Old 11-18-2008, 08:25 AM
army_sarge07 army_sarge07 is offline
Also you may want to check if there is a small piece of loose metal in the bottom of your tranny, whether original or 5 speed tranny a small piece of metal can jump up into the fluid on hard take offs and clunk in a gear or two, so be careful
